I have N804's and HTM-2 up front. I acquired three amps second hand, to use one for each speaker. On advice of my B&W dealer, I set up the amps each with their own custom-made Y-cable. The left pre-out goes to one amp in both L & R channel. That amp is wired to the left N804 in a passive bi-amp mode. The right pre-out and the center pre-out each go through Y's to their own amp L&R channel, and are similarly wired to their respective speakers. The amps I am using are all Rotel RB980-BX at 120 wpc. NEWBIE QUESTION: I see lots of threads suggesting more power is better, but I am perplexed about the classic question of passive bi-amp vs. bi-wire (I've read about it, and you'll probably agree it's just not obvious). Given that I COULD switch each amp to bridged-mono, getting 380 watts each that I can dedicate to each speaker, SHOULD I? Bi-wire it? Will the performance characteristics of the amps degrade (lower damping factor, higher distortion, other)? Does anyone have experience with this type of comparison? I'm sure to hear "try it and see how your ears like it". OK, I could do that.
ops: But, I am hoping for feedback from someone other than my local salesman (who by the way doesn't work there anymore) and I'm sure you guys have good thoughts on this! Thanks in advance for your patience and kind words.
