1055 not using subwoofer in PCM2CH
  • soopa
    • May 2003
    • 21
    When listening to a CD in PCM 2CH the receiver doesnt utilize my subwoofer even tho it DOES display the LFE icon on the front display.
    How do i fix this?
  • Scarp
    • Mar 2003
    • 632
    You probably have your front speakers set to "Large", which makes it not use the sub.
    So, set your fronts to small and it will use the subwoofer.
    Or you can use the subwoofer's crossover by setting the subwoofer level to "MAX" for stereo mode. Keep the fronts on large.
    • soopa
      • May 2003
      • 21
      awww sheeeet. thats it!
      thanks man.
        RSP-1066 / RSX-1055 etc. Frequently Asked Questions (FAQ)
        by Andrew Pratt
        Rotel has a FAQ available here that may answer some of your questions. We've added several points of our own as well below.
        1. How do I know what firmware is installed on my processor?
        Answer: Simply press and hold the mute button on the remote and it will be displayd on the LCD...
        15 April 2003, 14:08 Tuesday
      • MCH
        RSX-1055 or Yamaha RX-V1400? Advice Appreciated
        by MCH
        Given our HT situation, which a/v receiver would you recommend: the RSX-1055 ($799) or Yamaha RX-V1400 (approx. $550):
        My husband and I are purchasing a plasma television for our master bedroom, and we'd like to set up a small 5.1 system for 80% television (emphasis on HD viewing when...
        17 March 2004, 22:17 Wednesday
      • doodleboytoy
        ROTEL 1066/1075 vs. 1055/1070
        by doodleboytoy
        I am strongly considering Rotel for my new HT setup due to the numerous positive reviews I read about it. Currently, my plan is to run Paradigm Studio 60 fronts, Studio CC and Studio ADP surrounds using either a Rotel 1066 + 1075 set-up or a 1055 set-up in a 25’ x 20’ room.
        Questions
        05 June 2003, 23:31 Thursday
      • Poul
        RSX 1055 Redirect Problem
        by Poul
        Hi All,
        My Centre rear speakers got cooked the other day!
        I'm not sure if I have a problem with my amp or I have set someting up incorrectly; here goes:
        In my set-up I power the centre, the surrounds and two centre rear speakers from the 1055 and I have a...
        18 March 2003, 04:17 Tuesday
      • BleakShore
        Stick to RSX1065 or go to 1055/1075 separates?
        by BleakShore
        I guess I'd like to hear/learn advices/experiences from those who have gone this route.
        That is, stick with the RSX1066, or exchange it for the RSX1055/RMB1075 combo? I bought it from Myer-Emco so I can do the exchange with no penalty.
        The reason I'm contemplating this...
        17 October 2003, 13:27 Friday
