I just hooked up my SVS 20-39pci to a brand new Rotel RSX-1056 and the subwoofer worked for about an hour. I turned the receiver off for about 15 minutes and when I turned it back on, there's no sound coming from the subwoofer. I also hear this popping noise no matter what button I push on the DVD player remote. Like when I search for a scene, I hear this pop coming from the sub. What do you guys think?
I need help
Tags: None
This same thing has happened to me a few months ago. Come to find out, I had the gain on my sub too high and it ended up damaging the driver. I dont mean to scare you but thats the reality of it.
Did you have the sub up too high? Before the sub totally went out, did it bottom out? Thats what happened to mine. It was not calibrated and I ran it too hot so it just killed the driver. If thats the case then you should call SVS and they will send you a new driver in return for your old one. Good luck- Bottom
You need to narrow down whether it's the Rotel sub out or the SVS sub in..
First make sure the gain on the sub is all the way down. Connect the sub cable to the output of your DVD/CD player. Play something and slowly turn up the gain on the sub. If the sub kicks on and you can hear what's on the disc, the Rotel is damaged. If you still can't hear anything, the sub is damaged.
Kevin D.- Bottom
Hi guys,
Found out last night that there's nothing wrong with either one. I just had to do the speaker setup. I haven't really had a chance to read the manual that much because we just moved in to our new house. Next thing to do is try to figure out how to save the setting so I don't have to keep setting it up everytime I turn the Rotel on. Just haven't had a chance to look at that part yet.- Bottom
even though the PCi20-39 is one of their lower end subs, I have it also. I find it fairly difficult to get it to bottom out. I have the receiver sub channel level set to -5 and half the gain on the sub about a little bit over half way up. If I'm doing this wrong, somebody please tell me what's the correct way to set it up.- Bottom
Nothing particularly wrong about your setup, however, if it were me I would have the sub set flat (0) in your receiver and set up the sub with the volume control a bit lower.Originally posted by BlazeMasterI have the receiver sub channel level set to -5 and half the gain on the sub about a little bit over half way up. If I'm doing this wrong, somebody please tell me what's the correct way to set it up.Jerry Rappaport- Bottom
by jewelHi,
I just got a new sub, and I am trying to figure out exactly what the setting on the C2 for "THX Ultra2 Sub Boundary Gain Compensation" does? Can someone explain this setting to me? Or is it something I just have to try to see if it sounds good?
Thanks,...-
Channel: Club Halo/Parasound
by dmanindfwJust a couple of months ago finished my first DIY sub using a Tempest with 500w PE plate amp. Unfortunately I didn't take the necessary steps to protect the driver and my ferret decided to put some large holes in the surround.
Now I am looking for a good replacement driver. Considering...-
Channel: Mission Possible DIY
by manauGood day everyone.
I Need your advice about what could be wrong with my first DIY... No sound comes out from the sub except a light "hum, hum, hum..." noise. I am using the DAYTON RSS390HO-4 15" HIGH OUTPUT SUBWOOFER
I connected an RCA cable to the "monosub...-
by efarstadI'm just a simple guy who loves HT. Like many I heard A LOT about SVS and their subs...then I saw that their new PCi line was coming out. I pre-ordered one of their 25-31PCi's and waited patiently.
Then the day came...my UPS tracking number! I couldn't wait to see if the Sub would live...-
by audioquesoSo I just purchased my SVS sub to accompany my Nautilus 805s, the PB12-ISD. This thing is huge. Well, I've been playing around with the placement and settings, but somehow seem a little disappointed. My room size is 18x30, but I have my actual sitting position set up more like 18x20. I have used...-
Channel: Club B & W Speakers
- Loading...
- No more items.
