What makes the Rotel sound? The difference is stark between the the RSX1056 and the other receivers I considered - of course subjective to taste. I tend to like crisp, almost raspy quality. Is that accuracy? Many of the others sound to smooth (muddy mid?) varying from dark to bright depeding on brand. What are the other design parameters that Rotel uses to create this sound quality?
Is the preamp portion more responsible for creating this sound than the amplification? WOuld imagine so since detail cannot be added by an amplifier, only intesify what's there.
RIght now the Rotel is very smooth and detailed, but want a little more tingle (brightness?) out of my speakers. Will a big amp change that?
One other quick question... (rather than another thread repeat)
Is the sub crossover separate from the hi-pass cutoff for speaker groups (activated when choosing small for the speaker group)?
Should create a glossary to define sound (open, bright, imaging, etc.)
