Rotel RSX with a side order of Magnepan MMGs
  • emf
    • 17
    Hello everyone,
    I'm a brand new owner of an RSX-1056, my first Roland and my first receiver in over 20 years. I have always been a confirmed separates guy, alternating between low- and mid-high end. Times change, and needing a receiver in the TV room, I couldn't imagine anything other than one of the two Rotels. My question is, How compromised is the Rotel's amplification when presented with five sub-8 ohm speakers? It has been asked at least once before, but the kicker was that the 1056 wasn't doing all the driving. I realize that Rotel draws the line at 8-ohms with the 1056 (not even bothering with specs below that), but has anyone tried a bigger load? Magnepans loom large on my wish list, even the most modest ones, which seem perfect for the small room. It doesn't look good for them with the Rotel, but all comments are appreciated.
  • psych_o_pat
    • 8
    Hi, I have a pair of MMG W (for the rears) on an rsx-1055. I use a high-end amp for stereo listening and use the rears with the Rotel when listening HT.
    My suggestion:
    -MMGs for the front with a separate power amp that will really do justice to these very good speakers when listening music.
    -MMG Ws for the rear and use them with your Rotel, you can connect also your center to the Rotel.
    I don't like that much the sound of the Rotel receiver when listening stereo because I have experimented on separates how good the Magnepans can sound. If you stress too much your receiver, the Magnepans will tell you because they are really resolving.
    I already tried a big load on my receiver (~3.4 ohms for my fronts and 5 ohms for the rears... at high volume the sound wasn't good) I then put my fronts back in my power amp and the fun began.
    Hope this helps
    • emf
      • 17
      Helps a lot. Thanks P O P.
      • psych_o_pat
        • 8
        Well, you could check how the MMGs will work with the rsx-1056 and upgrade to a separate amp for the fronts if the rsx is not up to the task. Why I tell you that? The MMGs are not as resistive as a dynamic loudspeaker with the same impedance. If MMGs have 4 ohms, il will act as 4 ohms for the entire frequency range. On dynamic speaker, sometimes the impedance may go deeper and that what's make an amplifier having hard time. My main speakers are rated 4 ohms for most of the frequency range, but they can go as low as 2.5 ohms (That's why it doesn't match well with my rsx).
        BTW, get MMGs for the fronts, not the MMG-Ws. While the MMG-Ws are excellent, they are not good music performers as the MMGs.
        • emf
          • 17
          Thanks again P O P. When the time comes, what I'll probably do is ask my Magnepan dealer, who is also a Rotel dealer, either the same question or, better yet, ask him to connect the M's to a 1056 and see what happens.
          Ed
            • 16478
            emf your dealer won't have any of the smaller MMGs on hand as those are available direcly from Magnepan only. Still the 1.6's should be similar to the MMG's as far as their load goes (set them to small and run a sub as that will take a lot of the load off the receiver and you wouldn't want an MMG to be set to large anyway)
            • emf
              • 17
              Andrew,
              Good point about the local unavailability of the MMGs. Thanks. I'm hoping that they work out. I'm pleased with the receiver (not a statment I expected to make in a million years), but I'd hate for it to be the reason for not getting the little MMGs. As long as the speakers don't audibly choke at moderate levels, I'll be relieved. My volume demands are modest. Sub will be part of the mix, and I suppose I could always take psych's route with a second amp if necessary, though space in that room is at a premium. Nice operation you run here.
              Ed
                • 16478
                emf might I also suggest you consider getting some aftermarket stands for the MMG's so they stand upright instead of leaning backwards. I found that to have a significant impact on the sound quality and was an affordable tweak (I made my own stands)
                • psych_o_pat
                  • 8
                  emf, in my opinion, (with no offence to the Andrew's suggestions which I think is more suitable for HT only listening), if you plan set the MMGs to small, then you could just buy the MMG-Ws instead (because you only get the benefits of the higher frequency range that MMGs can deliver if you set your MMGs to small. I think that one of the most improving areas between the MMGs and the MMG-Ws is the bass extension; MMGs are excellent when reproducing music even without a sub, where MMG-Ws just can't live without.
                  If music reproduction in a concern (good plain stereo), better get the MMGs and set them on fullrange. In stereo, when powering only the fronts at moderate volumes I don't think that the Rotel will suffer at all; it has a nice amount of power. You may finish by buying and external amp just because you want a more open and transparent sound to get the most of your beloved MMGs. I have tried the MMGs with a Bel Canto eVo II; you cannot imagine how good these inexpensive speakers are.
                  Get the MMGs!!
                    Rotel 1055 receiver
                    by Andrew Pratt
                    I have been given a chance to audition the new Rotel 1055 receiver for you guys from the kind folks at Rotel! It arrived the other day but with other commitments I haven't been able to spend any time with it yet but I will so stay tuned I want to run it through its paces and see just how good it is...esp...
                    16 August 2002, 14:53 Friday
                  • dallaskruse
                    Rotel 1066 - Zone 2 - Remote Control
                    by dallaskruse
                    Products: Rotel 1066 and RR-969 remote Control
                    I am at the tail end of adding a Logitech Harmony to my parents' Home Theater.
                    They have a Rotel 1066 receiver along with the Rotel RR-969 remote.
                    Zone 2 works great when accessed via the front Zone button on...
                    19 October 2014, 09:59 Sunday
                  • Perry
                    Installation of new Rotel 1055 receiver
                    by Perry
                    I am buying a Rotel AVR RSX 1055 on 'cash and carry' basis, i.e. I have to install and get it running by myself. The dealer is 200km away from my home. I am also buying Paradigm Studio 60s, Studio CC and Studio 20s speakers from him for a 5.1 system along with Tempest subwoofer from another source....
                    21 June 2003, 02:11 Saturday
                  • shah
                    Rotel RB-1080 + Rotel 1056 + B&W 602s3's?
                    by shah
                    I just got myself to get a Rotel 1056 receiver. Stepped up from a Yamaha RX-V750 receiver. Heard a Big jump in sound quality. What do you think? Anyway.. I have a couple of questions about adding a 2 channel amp to my Rotel 1056. I had originally thought about adding a Rotel RB-1070 but reading...
                    10 March 2005, 00:12 Thursday
                    Receiver vs true pre amp comparison
                    by Andrew Pratt
                    I know this could likely have gone in the Club Rotel but I wanted to show people that receivers can make decent pre amps in some cases....
                    As luck would have it I am presently lucky enough to own both the Rotel 1055 receiver and the Rotel 1066 pre amp. For those that don't know about...
                    04 September 2002, 10:32 Wednesday
