How to set levels for rear surround speakers?
  • jakermc
    • Nov 2001
    • 24
    I finally got around to adding rear surround speakers to bring the system up to 7.1 and I have a few questions:
    How has everyone gone about setting the speaker levels for proper playback levels. I remember hearing somewhere that adding the rear speakers doubles the volume output in reference to the front, and therefore it would be incorrect to set all 7 speakers to the same level (using test tones). Is the correct way to set all the speakers to the same level using test tones and SPL meter, then reduce the side surrounds and rear surrounds by 3db each? Or maybe just reduce the rear surrounds?
    Does this problem exist only when engaging the rear surrounds on material that have not been specifically encoded for 6.1? For something that was properly mixed for 6.1, like Gladiator or Haunting, does the sound engineer properly account for this and mix the levels accordingly? If this were the case, I would assume that all the speakers should then be set for the same level.
    Complicating the issue is the difference between 6 and 7 speaker set-ups. It would seem to me that whatever the correct setting is for a 6 speaker set-up, a 7 speaker setup would require each rear surround speaker to be set at a lower level since you now have two speakers reproducing the same signal.
    Please share your own experiences and settings with me. Thanks!
  • Razvan
    • Jan 2002
    • 115
    "I remember hearing somewhere that adding the rear speakers doubles the volume output in reference to the front, and therefore it would be incorrect to set all 7 speakers to the same level (using test tones). Is the correct way to set all the speakers to the same level using test tones and SPL meter, then reduce the side surrounds and rear surrounds by 3db each? Or maybe just reduce the rear surrounds?"
    I used the test tones and the SPL meter to set the same level for all 7 speakers. I tried reducing the surrounds' level by 3 db but that didn't sound right. What did you do?
    "Complicating the issue is the difference between 6 and 7 speaker set-ups. It would seem to me that whatever the correct setting is for a 6 speaker set-up, a 7 speaker setup would require each rear surround speaker to be set at a lower level since you now have two speakers reproducing the same signal"
    Anyone???
    Razvan
    • BW4me
      Adding rear surrounds advice needed
      by BW4me
      I currently have a pair of CDM7NT's for my speakers with the matching CDMCNT center. I'm now trying to decide what to ad as my rear surrounds. I've been temporarily using my old paradigm bookshelfs some of the time because I have to set them up on a counter behind seating and run the wire across the...
      18 April 2006, 23:46 Tuesday
    • BlazeMaster
      DS6/DM600 as rear surrounds?
      by BlazeMaster
      As title says it all, which should I go with to use as rear surrounds? I have the Denon 2805 which is compatible with DPLIIx and will be using the DS6 as side surrounds for sure at about 2 feet above ear level when sitting down. The saving of $$ by going to DM600 can apply to my upgrade of fronts...
      10 October 2004, 20:56 Sunday
    • happy
      Rear surrounds and center channel size vs quality
      by happy
      I have a pretty small living room - 12 x 12 - in which I now use a pair of Natalie P's in a two channel system which sound wonderful, but I am wanting to switch to a 5.1 HT setup to expand my movie listening. I will use the Natalie's as my main/front channels and was thinking of using a pair of cr...
      20 December 2007, 22:07 Thursday
    • mskvarenina
      Location of rear surrounds
      by mskvarenina
      In a 21 x 14 sized room I can easily mount rear surrounds (in a 5.1 system) on the rear wall (14') but how mad is this compared to moving them to the sides?
      23 October 2011, 22:30 Sunday
    • Doug S
      Receiver connectios/rear surrounds??
      by Doug S
      Hello...I have a couple questions for you guys and wodering if you can help me out here....I have a yamaha 5280 receiver...I have it hooked via my digital output coming out of my PC to digital imput in on receiver is this the best source or am I better off going analog signal???
      29 January 2005, 11:23 Saturday
