Receiver connectios/rear surrounds??
  • Doug S
    • 19
    Hello...I have a couple questions for you guys and wodering if you can help me out here....I have a yamaha 5280 receiver...I have it hooked via my digital output coming out of my PC to digital imput in on receiver is this the best source or am I better off going analog signal???
    Also I have been trying to find a descent pair of rear surrounds for my system and have come across some Paradigm Cimena ADP'S which sound pretty descent for 199.00 has anyone had any experiances with these speakers or something comperable?...I would welcome your imput!.....thanks
  • jakermc
    How to set levels for rear surround speakers?
    by jakermc
    I finally got around to adding rear surround speakers to bring the system up to 7.1 and I have a few questions:
    How has everyone gone about setting the speaker levels for proper playback levels. I remember hearing somewhere that adding the rear speakers doubles the volume output in reference...
    11 January 2002, 08:34 Friday
  • rumatt
    Looking for suggestions for on-wall or even in-wall surrounds
    by rumatt
    Does anyone know of designs for DIY surrounds? Preferably that would match well with the TMWW's that I might build in the future? I'm psyched to build some speakers, and I desparately need better surrounds. I'm starting to think they're a good place to start, rather than tackling the TMWW's first....
    21 September 2006, 19:58 Thursday
  • JamesB77
    Surrounds - Build or Buy??
    by JamesB77
    Last year I built a set of Dayton RS TMWW Mains and WTMW Center. I switched out the mid and tweeter for Seas Millinneum. I now need some surrounds to go with them and have a couple of options.
    1) design and build both rear and side surrounds.
    2) buy the Triad Inwall Bronze for the rear and...
    19 October 2011, 19:55 Wednesday
  • slayer
    Question about AUX outputs for a Rear Sub.
    by slayer
    My question is about programming for a rear sub. I have my front/main sub hooked up to the LFE/sub preout. No problems here. I have another sub in the back of my room and it is hooked up to the AUX 2 output to mimic the main sub. No problems here.
    I want to try my rear sub as a dedicated rear...
    01 January 2006, 16:54 Sunday
  • BlazeMaster
    DS6/DM600 as rear surrounds?
    by BlazeMaster
    As title says it all, which should I go with to use as rear surrounds? I have the Denon 2805 which is compatible with DPLIIx and will be using the DS6 as side surrounds for sure at about 2 feet above ear level when sitting down. The saving of $$ by going to DM600 can apply to my upgrade of fronts...
    10 October 2004, 20:56 Sunday
