Advice on CD vs DVD player
  • BW4me
    • 75
    I currently have the DTR 5.5 receiver with the DPS 5.5 DVD player and a pair of B&W CDM 7NT's, which I use for both music and movies. What I'm wondering is if I really need a seperate CD player like the CDC 3.4 for better music listening or is the difference that I will gain is just the 6 disc holder?
    Steve
  • allmodcons
    • 12
    I would not think that you will gain a significant enough benefit from that particular upgrade to warrent the purchase. In fact using the D/A converters in the recievier via an optical or coaxial digital connection will probably give you better sound than the internal DAC of most under $1000 dedicated CD players. I personally own an RDC 7 and have found those DACs superior to both my Pioneer DVD player and Nakamichi CD player. Obviously the DTR 5.5 is in a different league than the RDC 7 but I still wager that the internal DACs are quite robust. I think you would have to spend an awful lot on a dedicated CD player to gain a significant benefit over the set up I just recommended. Of course if the disc changing mechanism is appealling you could always get the changer and run a digital output to your receiver.
    • BW4me
      • 75
      I mentioned the CDC 3.4 six disc changer to someone else and he told me the extra motor mechanism was a bad idea for audio quality. Is this the case or will it make a noticable difference at the equipment level that I'm currently at anyways?
      • allmodcons
        • 12
        I remember often hearing that the extra mechanisms in changers degraded sound quality but I always thought that this was more to do with price point than anything else. The actual spindle/clamp that holds the disc is what really matters and the fact is that the changer mechanism only delivers the disc to the spindle/clamp. The reason I think that sonic differences exist between changer and similarly priced single disc units is that money was spent on the changer component so compromises had to be made in other areas, like DAC's and power supplies. Running a digital output would negate this to some degree.
        Please don't sell your system short, it is potentially a very revealing system assuming that your speakers are set up correctly. In fact, I personally run B&W CDMNT 1's as my mains in a system that includes a REL Subwoofer, VPI TNT 'table, SME V tonearm w/ Argo Cartridge, McCormack Pre, Integra Research RDC 7 Pro, and a Carver Sunfire amp. I have auditioned other speakers in house and I must say that I have not felt the need to upgrade although my entire system has changed from the time I got them. The tweeter in the CMMNT line is absolutely fabulous.
        • BW4me
          • 75
          Thanks for the helpful feedback. I actually really enjoy the set up I have for now, which is a long jump from where I came just six months ago. It seems to make the most sense to me to just enjoy it until I can go to separates someday. But I'll probably always hang on to the speakers, there's just so much detail and seperation in my music now.
          • allmodcons
            • 12
            Those speakers will definately last you through several upgrades of source and amplification components, if I where you I would save the money you where contemplating spending on a CD player and put it away for seperates or even better. . . a turntable!
            • LikeCoiledSteel
              • 210
              Hi BW,
              I use the 7nt's also. Great speakers with the right equipment. If your receiver has preamp outs, I would try to hook up a seperate amp. it will make a big difference.
              Steel
              • BW4me
                DPS 5.5 & DTR 5.5 Help
                by BW4me
                This week I've experienced the following strange behavior with both my DPS 5.5 DVD player and my DTR 5.5 receiver.
                On the 18th (one day after my 3yr warranty was up) while trying to play a movie there was no sound. I switched the receiver to an FM station and it played, so I assumed...
                21 March 2008, 18:27 Friday
              • mdbirkett
                DTR-6.6 question
                by mdbirkett
                I just added a DTR-6.6 to my Integra family (I already have a DTR-5.5, DPS-6.5 and CDC-3.4). The receiver works fine (and certainly sounds better than the old Carver that it replaced) but the StandBy light does not come on. The manual indicates that the light should be on whenever the unit is on standby,...
                20 October 2008, 13:41 Monday
                The Saga Continues, my new CD player is:
                by Lex
                Out of this world! (Jupiter) ha!
                There was one technical snafus due to shipping. I mentioned it in the other thread, that the display color cover slid down on one side. The center ring of the flip top cover is loose, and as it turns out is supposed to be, because the chrome ring on the...
                22 November 2001, 00:21 Thursday
                Decision Made on new CD player
                by Lex
                Exciting huh?
                Actually, it's surrounded by one of these:
                Now, I know, you folks in the SACD camp are not to happy with me about now. But this is my moment, so hear me out!
                Quote from Rega's website:
                20 November 2001, 02:35 Tuesday
              • Bonzo
                DD/DTS decoder in RDC-7 or Panasonic RP-91 DVD Player
                by Bonzo
                Would it be better to use the DD/DTS decoder in the Panasonic RP 91 DVD player and go into the RDC-7 using its analog inputs or using the the digital input on the RDC-7 and use the RDC-7's DD/DTS decoder?
                All other things being equal, the decoder in the dvd player would be more convenient....
                10 October 2001, 10:34 Wednesday
