How much power for 602 S3s?
  • JasBW
    • 5
    Would 120WPC be sufficient? I'm aiming to get thier full dynamic range into play.
    Thanks.
  • Aussie Geoff
    • Oct 2003
    • 1914
    It depends...
    JasBW,
    The answer is "it depends on what sort of Watts we are talking about" For high quality separate amplification - the answer is "absolutely" - for some mass market Receiver with (frankly) quite limited current drawing capabilities and amplification - their 120W would be nowhere near as good...
    That aside the B&W 600s are relatively easy to drive and are commonly driven by Receivers etc - but love (and benefit from) quality amplification (either separates or a top quality Receiver). They are rated at up to 120W (unclipped) per channel - but I have heard them "singing" on both smaller and larger amplifiers. One of the main challenges is the amount of bass you put through them... If you are setting up a HT and using a sub-woofer then a lot of the power drain on the amplifier will go...
    Now - what were you going to use?
    Geoff
    • JasBW
      • 5
      A Rotel poweramp driven by my Maranetz SR4200 reciever as a temporary preamp.
      Would they benefit from 200 WPC, or will 120 WPC be plentiful?
      • Mark_C.
        • Jan 2003
        • 386
        120 wpc is plenty for the 602s, although I'm sure there are many here who would say 200 wpc is the bare minimum for powering anything. Realistically though, the 602s with a sub and powered by a Rotel should sound sweet. I power my Nautilus 805s with a Rotel 1075, which is 5 channels, 120 wpc. Some would claim the 1075 is too weak to bring out the best in the 805s, but that notion is absurd. The only difference I noticed between 200 wpc and 120 wpc on the 805s was the loudness level, and the 1075 is plenty loud for me.
        • Aussie Geoff
          • Oct 2003
          • 1914
          JazzBW,
          Since you are using a separate Rotel Power amp - (presumably the RB-1070) you will be just fine with the 120W on those speakers. The only reason you would consider more power is if you were thinking of upgrading speakers in the medium term - in which case the larger RB-1080 would give you more headroom. Even so the RB-1070 is very versatile and would find a place in your system for many years.
          As you say - the next upgrade will be the pre-amp or pre-processor (if you are into Home Theater)
          Enjoy and let us know how you go
          Geoff
          • P1et
            B&W 602 S3 vs. XT2
            by P1et
            As much as I love my 602 S3s, I am thinking about upgrading to the XT2s. My wife and I have recently moved into a house with a smaller living room and we feel the 602 S3s are a bit too big.
            What does everyone think of the XT2s? I have not seen too many reviews on them.
            15 September 2008, 21:59 Monday
          • Jon S
            Matching center to 602 S3s
            by Jon S
            This is my first time posting here, but after reading so many of threads I'm more comfortable with my choice of 602 S3s to replace a set of Infinity RS9Bs that were 20 years old. After about 20-25 hours these B&Ws are really starting to open up.
            Now I need a center to go with the...
            18 February 2005, 16:33 Friday
          • FSonicSmith
            HTM7 a good idea in a 603/602 system?
            by FSonicSmith
            My dedicated HT room (which I'm still in the process of completing) will have a Rotel 1056 receiver, a Denon 2910 DVD, two 603 S3s in the fronts, and 2 602 S3s in the rear. I am going to drive my fronts with a separate amp, a McCormack DNA-1, in order to free up the receiver's power supply (I already...
            01 March 2005, 12:15 Tuesday
          • P1et
            B&W DM7s or 602 S3s?
            by P1et
            I have the opportunity to buy some B&W DM7s. As we all know, they are B&W flagship speakers from the late 70s and early 80s. My father still uses them as his fronts.
            I can pick them up for $300. Or I can buy some new 602 S3s for $600.
            What speaker would be best?...
            03 May 2006, 15:27 Wednesday
          • DM3000 Owner
            N801 Amplification
            by DM3000 Owner
            I need to change my name here. I just picked up a set of N801's today. They are still in the back of my truck because I neede someone to help me move them. I'll get them set up tomorrow.
            I ordered a QSC PLX 3002 amplifier on Friday. I already have a 1202 and have used it for years...
            12 June 2006, 02:11 Monday
