Need floor spike solution for N802 and ASW4000
  • digitalman
    • 29
    I have B&W Nautilus 802's and an ASW4000 Sub and am looking for floor spike solutions for them both. B&W no longer supplies feet or spikes for these and could not even tell me how tell the feet are supposed to be for the sub.
    The 802 has metal plates with a roller wheel on the bottom. If i remove the 3 screws it comes out and simply leaves a large approx 3" hole. I could make a plate to go over that and screw spikes into that i guess.
    My ASW4000 has no feet at all. I am unsure how tall the factory feet are supposed to be but it is down ported and the pics look to be at least 2 inches I have thick carpet and padding so I would want a 3" spike for it i believe.
    It has a hole on the bottom that is about 1/2" diameter and I think I could get spikes with a threading piece i could put in there.
    Any tips would be appreciated!
  • TomScrut
    • Nov 2013
    • 532
    The spikes for the N802 are the same as for any 802/800 since, so no they maybe dont make the original foot kit but you can still buy from B&W a foot kit that works. So you just need to buy a kit for the diamonds, and it is even under the N802 on the parts page:
    This shows what the feet look like on your sub:
    Music: Intel NUC -> Antelope Zodiac Platinum -> Classe CA-2300 -> B&W 802 Diamonds & 2x SVS SB13U
    • digitalman
      • 29
      Thanks, that is good to know they are the same. Still over $500 for spikes is a bit expensive. I will have to think about that or continue to look for a 3rd party solution.
      • TomScrut
        • Nov 2013
        • 532
        Why not leave them on the rollers? That's what I do.
        There are thrid party spikes for the 802s but as they are deemed an 'upgrade' then they are generally more expensive and better made than the B&W ones. Which are very well made themselves so I cant see the point in a more over engineered solution.
        • madmac
          • Aug 2010
          • 3122
          I hate to be a poo-pooer of fine audio but I just can't see how spikes could make any major (if any) difference in a speakers performance. Assuming the speakers were in the exact same location, I would love to see if someone blindfolded could tell the difference. I doubt it !!
          Dan Madden :T
          • windshear
            • 243
            Just a warning to beware. The original N802 used a different spike kit .
            The new 802D came out with the model referred to above and was a reversible spike that had rubber feet on the other side for delicate surfaces.
            This compares the two spikes.
            Im not sure if they are compatible in terms of the spacing on the drilled holes. The reason I mention this is I had a problem with my new 800Di's. The three holes of the spikes would not align with the holes in the base. I suspect they mixed up versions(between the D's and Di's) when putting in the kit in the box. They had to send a new replacement kit to me after not one of the spikes would fit.
            • TomScrut
              • Nov 2013
              • 532
              The link I put to the parts website shows the new spike kit is compatible?
              Also the castor is the same part number and that fits into the sane holes!
              Sent from my HTC One M9 using Tapatalk
              • TomScrut
                • Nov 2013
                • 532
                Mine were slightly improved going onto spikes but not to the point of being worth the inconvenience of not being able to move them myself!
                • Amarkus1
                  Question for N802 Owners?
                  by Amarkus1
                  I just got my N802 Demos. I got everything but the spikes and or rubber feet. Now are the 802's supposed to come with spikes and feet to replace the rollers? And if so are they a special type of spike? I ask this because I have a set of 6mm Soundcare spikes from my 803's. I assumed I could use...
                  02 July 2005, 09:41 Saturday
                • chin kwan
                  N803 upgrade to N802, Is it worthwhile?
                  by chin kwan
                  I am currently using Proceed PAV+PDSD feeding Proceed Amplification for the center channel, using Mark Levinson 23.5 driving front channels, cheap amplifier driving the rear surrounds.
                  My current set-up are as follows: N803, HTM1 and SCM1. I had a Mirage BPS-400 sub that I sold recently.....
                  20 July 2006, 13:00 Thursday
                • tizeye
                  Speaker Spikes and Wood Floors
                  by tizeye
                  Currently building Zaph's SR71 and matching stands. First primer coat on drying on sands as I type. Having difficulty deciding how to spike the stands.
                  With my sub, PE's 10" Titanic, I quickly learned pointy spikes + wood floors = disaster and the separate floor plates are a joke...
                  23 October 2009, 06:40 Friday
                • RNKC
                  To spike or not to spike, that is the question ...
                  by RNKC
                  Hi everyone. So I've read that putting my N802 on spikes instead of the castors can make a big difference. To those who have spiked, what have you found?
                  My N802 currently live on top of carpet which in turn is on top of cold, hard concrete. (I live in a high-rise apartment.) To my ears...
                  06 February 2006, 14:20 Monday
                • William
                  802, 801 and 800 caster/spike/feet question?
                  by William
                  Wondering what people do for feet on their 802, 801 or 800 speakers. I just got a pair of 802's a couple of weeks ago. My dealer ordered the spike/feet sets and I got them yesterday. He said they are extra (no cost to me) and don't come with the speakers (seems strange). To my surprise they actually...
                  11 February 2009, 14:03 Wednesday
