technical help before buying
  • nimrodasas
    • May 2011
    • 145
    i want to order cm5 and stav 24 stand(the only one i cant get here)
    is the stand can fit to the holes in the speakers?
    cm1 didnt match at all
    please some one who knows..
    thank you for your help
  • j1982
    Rotel 1520 integrated amp, B&W CM1 vs CM5
    by j1982
    Hello, I just purchased a Rotel 1520 integrated amp, I am setting it up to my iMac and have ALAC files for music (still searching for a DAC under $500). My system will be in the living room of an apartment (about 12x13). Which speakers do you recommend, B&W CM1 vs CM5, I have listened to both at...
    30 August 2011, 16:10 Tuesday
  • j1982
    Rotel 1520 integrated amp with B&W CM1 vs CM5
    by j1982
  • Mark_89
    Upgrade from B&W 685. 703? CM5 S2.
    by Mark_89
    as a long-time fan of B&W I have enjoyed my 68x-series theatre (fronts: 685, center: htm62, rear: 686 with a BK XXLS400 sub on a Marantz SR5003) for many years now. However, recently I have upgraded my job and now it's time for the speakers to follow suit. I absolutely love...
    28 November 2014, 02:29 Friday
  • windmiller
    Rears for 703/HTM2 system
    by windmiller
    I am looking for some rears to go with my 703 fronts and HTM2 center. I know the obvious choice for rears is 705's but I am wondering if there would be other B&W rears that might match the 703's as well or better. I am certainly going to be buying used and want the rears in walnut to match the...
    13 December 2008, 10:09 Saturday
  • nimrodasas
    help about 800 system
    by nimrodasas
    after alot of suggestion here in this forum i ordered 800 series of b&w
    i ordered 804Di with Htm4Di and m6i as integrated and just waiting to lx85 or 75.
    i have few question ..
    i think for start not to use subwofer the system is 70% movies 30% music.
    and i dont have...
    22 August 2011, 10:22 Monday
