Please help!--2 subwoofer connection
  • halobelo
    • Jun 2008
    • 8
    Currently I have my B&W PV1 hooked up to a RSX 1065 (Preout SUB 1) via the Coax sub cable for home theater use.
    I just bought a second PV1 and wish to hook it up to my RSX 1065.
    Should i use the connection Preout SUB 2 (on th RSX 1065) via Coax sub cable or is there a better solution?
    (Front -- XT4, Center X-Series B&W, Rear--XT2).
  • wgriel
    • 241
    I can't imagine why not - if you've got two sub pre-outs I'd think that would be the way to go.
    • halobelo
      • Jun 2008
      • 8
      ...or Y-cable + connect both PV1 on 1x Preout SUB (1)?
      • RobP
        • 4747
        can they be daisy chained?
        Robert P. 8)
        AKA "Soundgravy"
        • halobelo
          • Jun 2008
          • 8
          i dont know what you mean with daisy chained...
          but i think there is a third option---PV1 Line In --to RSX SUB Preout (1)---and then connect Line Out PV1 to Line in of the second PV1...what would you suggest?
          • RobP
            • 4747
            daisy chained would be where you can connect the subs together if they have both an input and output on the back, thus creating a chain off of one sub out line.
            Robert P. 8)
            AKA "Soundgravy"
            • RobP
              • 4747
              just checked the B&W website and it shows that the sub does have a line out, so you should be able to daisy chain them.
              So it would be Sub out on the RSX to line in on the 1st PV1, then line out from 1St PV1 to second PV1's line in.
              Robert P. 8)
              AKA "Soundgravy"
              • halobelo
                • Jun 2008
                • 8
                do you suggest that this kind of connection is better than connecting every of the both subs to one preout of the amplifier?
                • kmcheng
                  • 253
                  I have two PV1 in my system. I suggest you use the Sub2 out in the RSX1065 and play with the settings (crossover, volumn, L vs. R, etc.) in the 1065 to maintain stereo seperation.
                  The other way is to use the telephone wires that come with the PV1 and connect them to the amplifier (not the processor). In this scenario, you adjust the settings on the PV1.
                  The two methods should sound identical if properly calibrated. However, I think it is much easier to use the Co-ax connection and make the adjustment on the processor.
                    • 1540
                    Ive used a RCA splitter.
                    Hard 1 male-2 female, plugs into my reciever LFE out and splits to 2 outputs. Then run a sub cable to each sub.
                    Thats just me.
                    B&W
                    • davisj
                      Questions about RSP 1066, RSX 1065, and RSX 1055
                      by davisj
                      I am a new member and could use some help with my new HT decision. I just got a projector and will buy the rest of my system by next week. I am ready to go with Rotel for the preamp, amdp, and probably the DVD/ CD. All in the family you know. I am considering the RSP 1066 with amp, RSX 1065, and RSX...
                      04 December 2003, 22:55 Thursday
                    • Glenn
                      RSX-1065 vs. RSX-1055
                      by Glenn
                      Does anyone know, aside from the power difference, if the internals and layout of these two receivers are basically the same, or is the RSX-1065 actually a step up, quality and parts wise? I'm trying to determine the real difference between these two products.
                      The RSX-1055 is actually...
                      14 June 2003, 20:05 Saturday
                    • Glenn
                      rsx-1065
                      by Glenn
                      First a hello to all. I've been reading the Club Rotel posts and the FAQ for about a week now. I decided to join, as it sounds like a great way to learn more about HT/Rotel.
                      I am in the process of upgrading my HT system. Now the proud owner of B&W 9NT's. Finally it's time for the...
                      09 June 2003, 03:21 Monday
                    • Arnold van Oostrum
                      RSX-1065 Issues
                      by Arnold van Oostrum
                      Like the RSP-1066/RSX-1055 the RSX-1065 also has some point that need to be enhanced or fixed.
                      The RSX-1065 has some flaws in decoding the sound format.
                      1) There seemes to be no difference in normal DD5.1 and DD5.1 EX sound. With both formats the RSX-1065 uses the CB speakers....
                      07 September 2002, 19:06 Saturday
                      RSP-1066 / RSX-1055 etc. Frequently Asked Questions (FAQ)
                      by Andrew Pratt
                      Rotel has a FAQ available here that may answer some of your questions. We've added several points of our own as well below.
                      1. How do I know what firmware is installed on my processor?
                      Answer: Simply press and hold the mute button on the remote and it will be displayd on the LCD...
                      15 April 2003, 14:08 Tuesday
