Hi All
I am a newbie with speakers. I am planing to get the B&W685 for my L&R ASW610 for sub, but not sure which centre (HTM61 or 62) to match it with.
I know B&W suggest using HTM62 with the 685. In terms of spec, the HTM61 has the FST midrange and it goes as low as 38Hz. Also the 685 has 1x ø165mm (6.5 in) woven Kevlar® cone bass / midrange while HTM61 also has 1x ø165mm (6.5 in) woven Kevlar® cone bass. So I was thinking they should match better than HTM62 since the 62 only have 2x ø130mm (5 in) woven Kevlar® cone bass / midrange. with the same cone size, would it match better? and with the additional 1x ø150mm (6 in) woven Kevlar® cone midrange for the HTM61 would it improve the sound?
Therefore, I am thinking to get the HTM61 for my centre.
Just want to know if this will be a good setup? anyone has this setup? will the HTM61 or 62 give me better sound when I match it with 685? any suggestion will help.
Thank you very much.
