Need Advice: Best bookshelf Speaker? Low power handling
  • timwat81
    I am looking to buy my first B&Ws to replace a pair of missions that came with a small denon personal component system. The am is only 70 watts (35 x 2) so i wanted a pair of b&ws that dont need a lot of power to sound good. I assume I need a pair with a power handleing rating of 25 or 30 w, so I was looking at the 600 series, dm600 or dm601 or the discontinued CDM1 or CDM2.
    I know the only way to achieve the true potential would be to upgrade the system, but it is for an office and I just want the best sound with what i got. Anyone that is familiar with the lines and has any advice on a good pair of small speakers.
    • 2901
    DM601s baby!
      • 1930
      I would agree with 600 or 601 (S3 of course). I owned both. I had 600s first. Very impressive even as main speakers. Yes, the 601s are fuller, but they do require more power and a space of their own.
      • hifiguymi
        • 1532
        DM601's would get my vote.
        Eric
        • KRC
          • 166
          I would go with the 600's for the system you are using and where you are using it.
          Kevin
          • dknightd
            • 621
            I use dm600 driven by a 4 watt per channel amp in my office. Plenty of good sound.
