Hy ,I`m new arroun here and I have a little problem .....i don`t know if B&W DM603 S3 are best for my reciver.........please give an advice ...thanks
please help B&W for YAMAHA RX-V659
Tags: None
I went from a Yamaha HTR-5730 to a Rotel RSX-1057 and the sound comparison is unbelievable! The Rotel does not have features that i won't use ever like the Yamaha, but it has the most important attribute of any AV Receiver - Sound Quality!- Bottom
Originally posted by digitalwariorHy ,I`m new arroun here and I have a little problem .....i don`t know if B&W DM603 S3 are best for my reciver.........please give an advice ...thanks
Yamaha 659 should have no problem driving the 603 S3. In fact, I have this Amp for almost a year now, driving my B&W CM1, Heco D'Appolito Signature CS, D8 Sunfire Sub and Bose AMII as surround. I am satisfied with it for the price I paid. If you go to Rotel's direction, the price might by twice as the 659. I don't think the sound quality is twice better than the yamaha.- Bottom
I have the htr-5960 (equivalent to RX-V659) and B&W 603s S3. I am very happy with the sound quality of the system and the features of the receiver. Yamaha and B&W have a reputation for being "bright" sounding and some folks worry that matching the two together will lead to an unpleasant sound. The B&Ws are "bright" in the sense that the frequency response doesn't roll off slightly at higher frequencies. The Yamaha is also fairly flat up to 20kHz, unlike Rotel which starts to round off below 20kHz.
http://www.audioholics.com/productre...aRX-V659p1.php
The differences are very small, but some folks feel that B&W pairs better with Rotel than Yamaha, as a result. If you're looking to buy speakers in the $1K range, I wouldn't worry about matching and instead buy the speakers that sound good to you.- Bottom
by beehivemy cousin is giving me his Yamaha RXv659....
i am almost about to buy a Denon but since the offer is free...
who wont say no? :W
my question will this drive my DM602 s3?
my current receiver is a Sony STR and i really dont like it....and all of
you will ...-
Channel: Club B & W Speakers
by defenderHi, I am considering buying a HT equipment, I allready know the speakers ( B&W DM603,600, LCR60 and a asw650 sub) and the dvd player (ONKYO 502), but i have to make a decision on the AV receiver.
In the store i go in Spain that's what i can get:
ONKYO TX-SR-602E---659 Euros...-
by mikegunnzHi all,
I'm new to both the forum and to quality audio. My previous ht was a htib system that cost $300 for receiver and speakers. Needless to say it was a real pos. While I'm still on a budget, I do have a little more $$ to spend and after doing a bit of research, I've purchased a yamaha rxv659...-
by MusfatherHey guys, im about to purchase a system.
But I am utterly confused on which reciever to purchase.
I will be using it 70% for HT/movies
Don't know if i should get the Rotel RSX-1057 or the Yamaha RX-V2600. The speaker setup I have is
Fronts - DM603...-
by weijstHi there people,
Well, the subject says it all...
Food for thought:- The DM601 + ASW675 combo is attractive as I can send the DM601's to the back when getting a pair of floorstanders as fronts (I'll never use a pair of floorstanders as surrounds)
- The advantage of having
- Loading...
- No more items.
