AVT-3700 vs ESI VLS-2000
  • John LaCava
    • Sep 2002
    • 38
    Hello all,
    I have some questions/problems related to video scalers. I first started using the XGA theater product from AV toolbox some years ago. I later switched up to the AVT 3700 (Trident DPTV 3D chip), from the same company, which I understand to be a re-branded Zinwell Briteview.
    I am considering trying a different scaler by ESI (VLS-2000, Genesis chip) and I am looking for any insights and oppinions.
    Some history/links first:
    These links show the 3700 and Brightview (the newer DVI brightview, however)
    Secrets of Home theater did a review of progressive scan DVD players that included the 3700 and Briteview for some of the tests
    http://www.hometheaterhifi.com/cgi-b...rch&articles=5
    There is now the an AVT 3800, but this seems to the same except for the exterior.
    However, I have recently considered trying this video scaler: VLS-2000 by ESI electronics.
    Although its says accepts 480i, the website says it takes ANY interlaced signal. And manual says it outputs at 50z (PAL)
    and this thread has some references to the ESI
    OK...so now the questions.
    Is there any reason to think the ESI would be better than the AVT 3700?
    Also what uses 960p and/or 1152p? The ESI does 960p (NTSC?) and 1152p (PAL?).
    I thought it works like this 640x480 = 480p NTSC = 576p PAL (640x576)
    But of course there is no equivelent computer resolution for 720p and up.
    The AVT 3700 does 720p but not 960 or 1152 and it also does 1080i (which the ESI doesnt do). Since I will be using the scaler hooked up to a tft monitor at wxga resolution (768x1280) I guess all the "p" specs dont apply to me.
    Well so there you have it. Just trying to see if anyone has used either of these, or preferably both, and failing that, if anyone thinks that the ESI might be better than the AVT preformance wise.
    Also, does has anyone heard of a firmware upgrade or different versions of firmware for the Avt 3700?
  • JazzGuyy
    Seeking a PAL to NTSC-capable DVD player
    by JazzGuyy
    I am interested in obtaining some foreign films on DVD which will be in PAL. I would like to find a DVD player that converts PAL to NTSC so I can use it with my U.S. spec Mitsu RPTV. I know about the Oppos but they only do PAL to NTSC through DVI/HDMI. I have an older set that only supports component...
    05 January 2006, 15:29 Thursday
  • greenhorn
    PAL and NTSC
    by greenhorn
    Crud, Crud, Crud... A disc that I really really want (The Secret Policeman's Other Ball) is only availible Pal - Region 2. Now I've been told that my DVD player (Arcam DV 78) can be recoded via the remote to play all codes. In reading the users manual it says related to the TV system settings (Auto...
    06 January 2008, 23:22 Sunday
  • Kees
    PAL / NTSC switching problems on 1098
    by Kees
    I have encountered a problem when switching between sources on my RSP 1098. When I switch from watching an NTSC DVD (progressive scan component video input) to PAL video (S-video input), the component output from my 1098 is monochrome (black & white)!
    I can 'reset' this by entering the menu...
    12 October 2003, 05:28 Sunday
  • saurabh
    PAL vs. NTSC DVDs in region free player
    by saurabh
    hmmm... my previous thread has led me to another question.......I know you cant play Region 1 DVD's in Region 4 or others but I also know that you have regionfree DVD players....or you can tweak your DVD's to be region free.......but the real question coming to my mind is :
    Can you play...
    06 May 2005, 06:47 Friday
  • peterS
    wierd coax PAL to NTSC question
    by peterS
    someone has two tvs purchased in Europe that she states are compatible with ntsc format
    her problem is is that she cannot screw in a coax as her coax inputs are not threaded
    i suggested she just get a cable box and be done with it, she suggested i find her an adapter instead.......
    09 March 2006, 18:43 Thursday
