DVD, but no S-vid or composite iputs on TV
  • Eric M L
    • 9
    One of my friends got a DVD player for christmas, but her TV doesn't have any composite or S-video inputs. Buying a new TV is not an option for her.
    Any signal converters out there that will allow her to send the signal to her TV via coax?
  • Bing Fung
    • 6523
    If she has a VCR the DVD could be pugged into a Line in of the VCR. She then selects the Line(x) on the VCR's input and it will pass the Composite video signal.
    A Video line converter can be purchased at RadioShack, I think this will do the trick.
    Bing
    Bing
    • Eric M L
      • 9
      Thanks Bing!
      I thought about recommending the VCR route, but I figured the Macrovision would cause a problem being routed through the VCR.
      • Bing Fung
        • 6523
        Your welcome Eric, I have not tried the VCR pass through, but assumed that macrovison is inabled only if you attempt to record the signal.
        Anybody know for sure?
        Bing
        Bing
        • rlabarge
          • Jan 2001
          • 67
          You want to avoid running the signal from the DVD player through the VHS player to the TV. On some VHS players this will cause the signal to be distorted when sent to the TV due to presence of Macrovision on many Hollywood titles.
          It would be better to get an A/C Receiver that supports Dolby Digital/DTS and provides a number of inputs for a VHS player, DVD player, CD player, etc. These are fairly inexpensive these days, and would be more usefull than just a video switch.
          Ralph LaBarge
          Managing Partner, Alpha DVD
          Author, "DVD Authoring & Production"
          rlabarge@alphadvd.com
          Ralph LaBarge
          • AndrewM
            • Oct 2000
            • 447
            Well I used to have a computer system's DVD player hooked up through the VCR and I did experience the macrovision problem. First out of the disks that I had at the time (only about 6-7) not all of them had the macrovision problem, or at least anything that I could see. Out of the ones that did the screen simply got bright then dark, but the picture was still viewable at all times, it just looked like somebody was playing with the brightness nob on the TV.
            A better way to do it would be getting some type of demodulator, you'll lose some picture quality (will still be better than the VCR), and on most you'll have to flip a switch to select the input, but you're already up from putting the DVD in the player. Or you could simply run all of your components through the reciever (if your friend has a reciever that has A/V hookups), most cable box's have composite outputs, VCR's have them and your DVD has them, then you can leave the switch on all the time on the demodulator and switch through the reciever. I bought one of these about a month after hooking it up through the VCR, I think it was around $15-20 at Walmart and lived with it that way for a few months until I bought a new TV.
            Andrew
              • 16478
              I just went though this with my sister's player. On her DVD player (an RCA) it had a connection for coax out via two RCA plugs and a smaller middle plug. Radio Shack has an adatper that will convert that into coax that you can connect to the VCR just like you would for a gaming system or a camcorder. I believe Radio Shack also sells converters to take compostie video into coax if the player doesn't have the coax out jacks.
              Macrovision will almost always be tripped when you send a DVD's image through a VCR even if you aren't trying to record anything. Coax inputs won't be affected though but composite will be. There are some DVD players that can defeat the macrovision but these are mostly the older Apex players and honestly they aren't the best players to use as a main dvd player.
              • pedalmike
                Composite and Component Outs
                by pedalmike
                When the RDC-7 outputs a video signal, I assume it has to be the same cable type that is coming in.
                For example, I can't have a VCR coming into VIDEO 1 through a composite input, and output it to my display through the Video 1 component outputs...I must use Video 1's composite out...correct?...
                23 March 2002, 16:34 Saturday
              • pglover19
                TV/VCR/DVD/Modulator HookUp to RSX-1055
                by pglover19
                I am new to the HT world. I am planning on purchasing a Rotel RSX-1055 receiver in the next couple of weeks. I have downloaded the owner's manual and see that there are a lot of video inputs/output. Can you explain or send me a diagram of how most of you have your video components (VCR, DVD) and TV...
                30 January 2003, 07:25 Thursday
              • zgeist
                newbie question - new receiver or video switcher?
                by zgeist
                First, I'm new to this HT thing - I *have* read lots of posts, but I'm still confused - so I thought I just ask. Second, I'm posting this in Club Rotel because one of the options I'm considering is the RSX-1055...
                Basically, I'm getting a plasma tv and I'm trying to figure out how best...
                27 October 2003, 23:44 Monday
              • Matt Broeska
                VCR POS
                by Matt Broeska
                hey everyone. just this past weekend my vcr died. no! no need for tears or condolences... i'll be okay. afterall, it's just a vcr. one of those $150 (cdn) things that only lasted 3 years.
                so now i wanna replace it and i'm wondering whether i should go with an s-vcr or not. it's YOUR job...
                19 February 2001, 10:47 Monday
              • toychris
                Reccomendations on VCR's
                by toychris
                I was wondering if any of you could give me a good reccomendation on a VCR. Is there any VCR's with component outputs that are reasonably priced? I am guessing that VCR's Video output is relatively low anyway, so s-video outputs would give about the highest quality of picture, right? I know that JVC...
                16 January 2005, 01:47 Sunday
