I will be spending about 4 months in Santa Fe and was wondering if there are any members from there. Looking to find out about record stores in particular.
Santa Fe N.M., need info
Mats
Mats Strömberg
Ah! It's a profit deal! Takes the pressure off! Get your weight guessed right here! Only a buck! Actual live weight guessing! Take a chance and win some crap!
Navin R Johnson (alias Steve Martin)- Bottom
Mats
Mats Strömberg
can I make one small suggestion? Right now you can use the letters to jump to say the "W" names but you can't use them for the location. Could you add a set or radio buttons or a drop down menu to allow the user to select either location or name. Then when the user hit "W" it would check which field the user wanted to search against and then jump to the "W". Make sense?
Originally posted by MatsFixat... Går nu att sortera på Location...
8O Huh? Anyone speak Swahili?
David - HTGuide flunky
Our "Theater"
Our DVDs on DVD Tracker
"I'm out there Jerry, and I'm loving every minute of it!" - Kramer- Bottom
Sorting and/or selecting on "Location" is a nice idea, but like so many things in data processing, its effectiveness is still dependent on the underlying data. We have a large number of members (117) who did not enter anything at all for location, and some who put in unusual ("home is where the CAT is") :>) or non-obvious place names like, for example, "west of Houston" that a scan of the list for "Houston" based on an alphabetical sort would miss (since the sort is from first character in the field forward rather than "contains") or "Puyallup" instead of "Seattle" (which almost no one except someone who lives there would guess). :>)
Bob -
As for record stores, it appears the best ones in Sante Fe are in Albuquerque. :>) You might want to check out the ones on this list: http://www.digitalcity.com/albuquerq...trecordstores/ For a longer list, click on"More record stores in your area." below the list that comes up with that URL.
Good luck!
Burke
PS -- as far as I could tell, not one member here has entered "Sante Fe" as their location.
What you DON'T say may be held against you...- Bottom
Originally posted by Burke StricklandSorting and/or selecting on "Location" is a nice idea, but like so many things in data processing, its effectiveness is still dependent on the underlying data. We have a large number of members (117) who did not enter anything at all for location, and some who put in unusual ("home is where the CAT is") :>) or non-obvious place names like, for example, "west of Houston" that a scan of the list for "Houston" based on an alphabetical sort would miss (since the sort is from first character in the field forward rather than "contains") or "Puyallup" instead of "Seattle" (which almost no one except someone who lives there would guess). :>)
and hey guys, didn't you learn anything from the Muppet show and the Swedish chef? :rf what a waste of air time that was in that case :B
Mats
HTGuideMats
Mats Strömberg
