Schematics Of Systems
    Saw this going on other places and thought it's a cool idea. Here's a simple schematic of my HT system.
    David - HTGuide flunky
    Our "Theater"
    Our DVDs on DVD Tracker
  • Kevin P
    • 10812
    What software did you use to generate that schematic? I've seen them, probably where you saw them and am tempted to create one for my system but I'm not up to drawing all those lines and boxes in Paint Shop Pro. 8O
    KJP
    My HT Site
      Kevin, I used Visio from Microsoft. It took about 15 minutes to generate.
      Our "Theater"
      • Kevin P
        • 10812
        Microsoft makes Visio? I didn't know that.
        I don't have Visio or anything similar, but I managed to cobble together a simple schematic of my system using Paint Shop Pro. It took me a lot longer than 15 minutes though. 8O
        KJP
        My HT Site
          Awww. I forgot about my S-video input from the RX-V1. Back to the drawing board. :?
          All better now.
          I thought MS did since it's under our Office tab on the startup menu at work.
          Our "Theater"
          • kgveteran
            XO schematics
            by kgveteran
            I've noticed that some schematics are all inclusive, meaning the hipass/lowpass/bandpass are on the same plan.
            Some are separated.
            Can I take a schematic that is all together and divide it up so the hipass is on one board,the bandpass is on one board and the lopass is on...
            09 April 2006, 14:04 Sunday
          • MrKazador
            Schematic help
            by MrKazador
            So I was lurking and came across a schematic I don't understand.
            I don't know where the positive and negative terminals would go(source). Usually I would see a ground symbol(negative) and signal generator(positive). This schematic has a circle with 2 lines coming out for...
            14 July 2010, 19:19 Wednesday
          • Horacio
            Anyone has a crossover schematic for 804S?
            by Horacio
            I'm looking for the crossover schematics. Anyone has them? 804, 803 would be fine. 802 might work too.
            I know I can just open my speakers and draw them, but I'm trying to avoid opening them just for this. yeap, could also say I'm lazy! :T
            Thanks!
            Horacio
            27 March 2010, 06:53 Saturday
          • Mark_89
            ASW750 malfunctioning; need schematics
            by Mark_89
            I am the owner of a pre-owned 5.2 set consisting only of B&W 700 series speakers colored in pretty rosenut; amongst which 2 ASW750s. Now, sadly, one of my ASW750s has died. When I was using it recently it was playing at lower volumes but now when i turn it on theres no sound...
            13 September 2016, 00:05 Tuesday
            by ---k---
