JVC XV-S6x DVD player (PAL/NTSC) Chip Mod - success
  • Patrick Sun
    • 1382
    For those interested in a DVD player that can be modded for multi-region play and already possesses PAL/NTSC conversion/playback, there is a mod chip hack for the JVC XV-S60/62/65 DVD player.
    I obtained the mod chip from a guy who mainly hangs around the AVS forum (go there and do a search on "JVC ckna", you'll find the guy...), so I will say that the mod chip does work. I paid $65 for the mod chip and instructions. The guy will do the mod for around $100 plus return shipping costs. I decided to roll the dice and do the soldering myself to save $40 plus shipping.
    I will confess that it does require a low wattage 15W soldering iron, solder, and a bit of soldering skill/luck to solder 8 wires to various points in the innards of the DVD player. You need to be quick and nimble with the soldering iron, apply just enough heat/solder to the connection point and move on to the next connection. There's a couple of connection points which were tricky, but I managed to make a good enough effective connection.
    The kit is pretty simplistic: one small 8-pin DIP mod chip, one 8-pin harness with 8 thin, long wire, small bit of heat shrink tubing to cover the mod chip/harness, and instructions for soldering locations for each wire, and how to change regions on the DVD player.
    The mod was a success. I followed the instructions on changing regions for the player, then I popped in a PAL DVD into my JVC XV-S65GD, and was treated to a wonderful video image on my TV with no muss, no fuss on my part. It automatically converts PAL video to NTSC video.
    So if you're handy with a soldering iron, and need region free/PAL-NTSC conversion, this might be the chip mod hack and DVD player for you.
    • 27460
    Pretty cool Patrick, congrats on a successful mod! So, what's the big advantage to this anyway, aren't most things available for NTSC that are available for PAL? Is there an image advantage? How about region free, what does that gain you? Just curious...
    Lex
    • Patrick Sun
      • 1382
      It all depends on what you "consume" as a DVD viewer. There's plenty of stuff that is simply not available in Region 1 (the US/Canada) but is in different areas/regions in the world, so if you want to view those DVDs in region 1, you need a DVD player that offers PAL/NTSC conversion to be copacetic with your TV set, and you need the ability to read DVDs outside of region 1 (thus the Region Code hack for this mod).
      Even if you have an all-region PAL DVD, when you feed a PAL signal to your TV, it's going look very distorted and ugly.
      If you want Japanese DVDs, they are region 2, but are NTSC, so you still need to able to read region 2 DVDs. If you want other DVDs, you need both capabilities to watch everything the world offers in DVD.
      Some DVDs never make back to region 1 due to music rights in the film. I have to wonder if that's what is holding up the Jackie Brown DVD.
      If you have to have all of the South Park episodes, you have to go outside of Region 1 to get them. And the list goes on and on...
      Again, it goes back to your DVD appetite.
      • greenhorn
        PAL and NTSC
        by greenhorn
        Crud, Crud, Crud... A disc that I really really want (The Secret Policeman's Other Ball) is only availible Pal - Region 2. Now I've been told that my DVD player (Arcam DV 78) can be recoded via the remote to play all codes. In reading the users manual it says related to the TV system settings (Auto...
        06 January 2008, 23:22 Sunday
      • JazzGuyy
        Seeking a PAL to NTSC-capable DVD player
        by JazzGuyy
        I am interested in obtaining some foreign films on DVD which will be in PAL. I would like to find a DVD player that converts PAL to NTSC so I can use it with my U.S. spec Mitsu RPTV. I know about the Oppos but they only do PAL to NTSC through DVI/HDMI. I have an older set that only supports component...
        05 January 2006, 15:29 Thursday
      • saurabh
        PAL vs. NTSC DVDs in region free player
        by saurabh
        hmmm... my previous thread has led me to another question.......I know you cant play Region 1 DVD's in Region 4 or others but I also know that you have regionfree DVD players....or you can tweak your DVD's to be region free.......but the real question coming to my mind is :
        Can you play...
        06 May 2005, 06:47 Friday
      • Kees
        PAL / NTSC switching problems on 1098
        by Kees
        I have encountered a problem when switching between sources on my RSP 1098. When I switch from watching an NTSC DVD (progressive scan component video input) to PAL video (S-video input), the component output from my 1098 is monochrome (black & white)!
        I can 'reset' this by entering the menu...
        12 October 2003, 05:28 Sunday
      • peterS
        wierd coax PAL to NTSC question
        by peterS
        someone has two tvs purchased in Europe that she states are compatible with ntsc format
        her problem is is that she cannot screw in a coax as her coax inputs are not threaded
        i suggested she just get a cable box and be done with it, she suggested i find her an adapter instead.......
        09 March 2006, 18:43 Thursday
