Cable Box issues/questions
  • Nolan B
    • 1792
    I have a couple of questions about the below cable box my cable company cant even answer.
    http://www.shaw.ca/en-ca/ProductsSer...ware-HDPVR.htm
    1. In the advanced setup menu there is an option called "4:3 Overide" and the choices are 480i, 480p or stretch.
    I already have "TV screen type set to 16:9 (because mine is)" and output set to 1080i.
    2. For some reason since I go my new cable box I can only set the sound options on my Processor to Dolby settings i.e. Dobly Digital 2.0; DD PL11 (music or cinima); Dolby Digital. I can not set to settings like 5 Channel stereo. This is not something I had an issue with in my last cable box. Any ideas?
    My guess would be that because you have your TV type set to 16:9 already, everything is going to be output to widescreen. So the "4:3 override" would be choosing how you want to have 4:3 material output to your widescreen TV. I'm guessing that by choosing "stretch" it will do just that to 4:3 material, stretching it to fit your screen, and the other two will put black bars on the sides to keep it displayed as actual 4:3.
    No idea on the sound issue.
    • Nolan B
      • 1792
      thanks for your reply. I am thinking it just over rides it since I have 16:9, your right. Makes me wonder why they have the "stretch option at all? If I have it set to 16:9 then it steches.
      with regards to sound Im guess that since its DD it only lets me choose DD settings..maybe for copy protection? For example if you play a DVD with a DD sound track you are unable to switch to 5 channel stereo.
        • 4158
        My HT receiver will only process audio in the same format as received. My HD cable channels are Dolby Digital D (most DVDs , too) and most everything else goes PL II. Example: I can't set my receiver to PL II if the source is DVD or HD cable. Of course , I have a cheap receiver so this may bear no relevance to your situation Just thought I'd toss it out there.
        • Kush
          Difficulty with HDMI input from Cable box to TV via receiver
          by Kush
          My set up
          TV-Sharp Aquos 46" 1080p
          Receiver - Pioneer Elite VSX84 TSXI
          Cable Box - Shaw Digital box (Canada)
          I tried to hook up the cable box to the receiver to take advantage of the HDMI connections. However the picture does not go through to the TV...
          04 December 2006, 17:45 Monday
        • mjames
          Samsung HT-P38: getting sound from cable box?
          by mjames
          I just got this 5.1 Samsung HT-P38 package and have a Scientific Atlanta 8300HD cable box and a Samsung LTP227W 22" LCD HDTV. My problem is I can't get sound from the cable box to go through my 5.1 speakers when watching TV. How would I do this?
          My TV has component 1 and 2 and L/R...
          26 November 2005, 15:03 Saturday
        • CPALIU
          RSX 1057 & Charter HD Cable Box 3500HD problem
          by CPALIU
          I'm running into a problem with my Rotel RSX 1057 & Charter HD cable box (3500HD). I have the cable boxed hooked up to the RSX-1057 using component cables to Component in 2. When I select video 2, I get the cable signal just fine from the cable box. Howeve,r when I push the menu option on the...
          18 August 2006, 11:31 Friday
        • june
          Comcast's new HDTV cable box!!!
          by june
          Hello All,
          Comcast has a new HDTV cable box verson 3 with a HDMI output. My sony HDTV only has a DVI input. The cable installer brought this new box with a HDMI to DVI cable. This didn't work properly. No picture after a hour or so of viewing. We had to switch back to component output...
          27 March 2006, 11:36 Monday
        • vasia
          Need help hooking digital cable box to the receiver
          by vasia
          I am trying to hook up Motorola digital cable box DCT2500 to my Marantz SR8300 receiver. I connected digital out of the DCT2500 (did not have optical out) to the digital in of the Marantz and it plays fine. THe only problem is that even when the program is listed on the TV as Dolby Digital, the receiver...
          24 June 2004, 08:51 Thursday
