Question on component cables
  • Doop
    • 22
    Maybe this is the wrong forum, but I'm curious about something.
    I pre-wired my house when it was built 10 years ago with double conductor high-quality RG6U coax, including a ceiling box in the designated HT. I'm in the process of installing a projector. I was bemoaning the fact that my prewiring was obsolete and was pricing component cables, and just for the heck of it, I compared the specs of the RG6U and good-quality (Monster) component cables.
    The impedence, capacitance and attenuation were almost exactly the same. I'm trying to imagine what other factors could have a noticeable effect in a relatively short (18-foot) run.
    It can't be this cheap and easy. Where am I going wrong?
  • Kevin P
    • 10812
    Quality component cables are made from 75-ohm coax with electrical specs similar to RG59 or RG6. Of course, the physical specs are likely different--component video cables usually have a stranded core and is more flexible than the RG6 you run inside the walls. But that doesn't matter for in-wall use. If you already have three (or five for RGBHV) runs of coax to your ceiling box, just pop on whatever connectors you need and you're good to go.
    • Doop
      • 22
      Another question on component connections
      My new projector has one set of 3 RCA inputs labeled Y, C(subB) and C(sub R).
      It has a set of 5 BNC inputs labeled GBRHV of which the first three also are labeled Y, P(subB) and P(subR).
      The user's manual says to use the C inputs for connecting to DVD players. I've done that; works fine.
      I've ignored the P inputs, assuming they were for a computer input, especially since the package included a VGA-to-RGBHV cable. However, the package also included three RCA-to-BNC adaptors, and in the user's manual it says to use the P terminals for connecting "progressive components (DTV Y/Pb/Pr)."
      The reason I'm confused is that the component output terminals on all my sources -- four DVD players and a Dish HD receiver -- are labeled P, not C.
      What's the difference, if any, in the way the projector handles the YBR signals it gets from the P and C inputs? And is there a reason they do it this way, other than to confuse me?
        • 16174
        HD vs. 480i. That's the difference. Your set which is either/or on the three connectors in the RGBHV set is intended for HD level component signals- 480P, 720P, 1080i. Your other ones are intended for 480i component signals, as would come from your 480i DVD player outputs, and Dish receiver. The different nomenclautre is for identification, so one will know that they're HD capable component inputs. 480i MAY also work on those inputs (for some sets they do), but most likely not.
        • Doop
          • 22
          OK, it's starting to filter through
          The Dish HD receiver gives me three output options: 1080i, 720p and 480p. But the regular Dish PVR receiver only gives me 480i, right?
          Experimentation is the only answer.
          My job and honeydo list will just have to wait. :W
          • Greg Stone
            HDTV component cables
            by Greg Stone
            Are HDTV component cables realy necessary for my new HDTV set, a Panasonic CT-36HX41, or will standard component cables suffice, like the ones I had used for the Colorstream inputs on my Tosh set?
            I will have the Tosh SD4700 progressive scan DVD player hooked up to my new tv, once it...
            07 April 2002, 21:48 Sunday
          • ghrays
            RSX-1055 Component video inputs
            by ghrays
            I recently changed my video display from a Pioneer elite PROHD510 with multiple component video inputs to a Panasonic 50" plasma HDTV with only one component video input. Therefor, I am using the component video switcher on the Rotel 1055 for the first time, to switch between my progressive scan...
            31 August 2003, 09:05 Sunday
          • silvercans
            Help. Terminating beldin coax for component cables
            by silvercans
            I've been searching for quite some time but haven't found any affordable solution for creating component cables from beldin 1694A and Canare RCAP-C53. Does anyone have suggestions, or know a cheap solution? If not, can I just use solder connectors (I'm proficient at soldering)
            26 November 2005, 23:54 Saturday
          • boostdfd3s
            Converting DVI-I to Component?
            by boostdfd3s
            hey every1,
            i recently built a HTPC with a radeon 9200SE for a vid card. Was banking on my 22" samsung LCD having VGA and DVI inputs but sadly that wasnt the case when i brought it home Also found out the hard way that you cannot have two High def channels in PIP because of the single...
            28 December 2004, 00:58 Tuesday
          • pedalmike
            RDC-7 OSD thru Component Outs?
            by pedalmike
            My current TV does not have component inputs. If I buy a new display that I can connect to my RDC-7 using component cables, will I be able to view the RDC-7's onscreen display?
            Will I have to connect another composite video cable to the monitor 1 output?
            14 January 2002, 20:23 Monday
