I've been searching for quite some time but haven't found any affordable solution for creating component cables from beldin 1694A and Canare RCAP-C53. Does anyone have suggestions, or know a cheap solution? If not, can I just use solder connectors (I'm proficient at soldering)
Help. Terminating beldin coax for component cables
Tags: None
Silvercans,
Your local Radioshack etc will sell you coax stippers and crimp tools... You can solder as well for a better connection... You'll most likely get a reasonable result but not as good as a professional cable.
Geoff- Bottom
Silvercans, try this at PartsExpress. Seems like the compression connectors are a great option that they just added, and they offer color inserts for the cables.
____________________
Erik
Just another case of the man trying to keep us down! :B- Bottom
Thanks for the link. Those looked promising until I saw the price of the compression tool ($100 :E ).- Bottom
by timetohuntI am new to the audio hobby. Have about 12k worth of music but nothing of an audio system to speak of yet. So I am working on it. Here are a couple questions about the coax audio cables.
#1. I realize that these are required in order to pass HT or surround information from a CD/DVD...-
Channel: Audio Hideout
by LonewolfHi all
After doing a search and reading alot of threads on this forum, i fear i may have either learnt alot or confused myself more than ever.
I have got a RSP 1066 (you figured that) and had some queries on how to get optimum sound out of it for 2 channel stereo from...-
Channel: Club Rotel
by ejfiiiHi guys, I finally got moved into the new house this weekend and spent the better part of the weekend (much to my wife's dismay) hooking up the HT. I have not had a chance to calibrate anything yet, but sat down a few times to try to watch some things on the TV, just to test drive the HD cable.
Channel: Club Rotel
by Andrew PrattI know 75 ohm is the standard for Video cables and digital coax cables but what about audio? I was led to believe that audio cables should be at 110 ohms but I've heard otherwise...whats the deal?
by Ross SmithI have been using a cheap Coax cable from my DVD player to my Rotel 1066 Processor, I was wondering will I hear any difference using a dearer $150 cable.-
- Loading...
- No more items.
