Rotel RA-1570 suddenly makes puff-noise from left channel
  • RotelBorn
    • Sep 2016
    • 4
    I got some really good suggestions here last year regardning an USB-humming noise, and now some year later, I might try this forum again.
    After being away for a week, returning home, switchin on my amp, suddenly I hear a constant "puff" from the left channel (speaker).
    It sounds like the noise you hear when switch off some systems, like a condensator is being decharged. Very weak noise but indeed noticable.
    The Hz is about 30, so every 2 seconds the "puff" will sound, it is a short sound, like 1/10 of a second.
    0s-[Puff]----------------------------------1s----------------------------------2s-[Puff]---------------------------------
    It doenst matter which input I choose, only disconnected ones are silent. And the amp even makes this noise while being only thing with power. My PC is connected via OPT-1 and USB. When turned off (PC) no puffing sound, but as soon as the Rotel gets a signals, the amp makes the "click" and start to amp, and then the puff starts.
    That is when I found the cause. And it made me a bit electric.
    The SUB-woofer line out is connected to a amped subwoofer (powered by an other outlet) and when I unplugged the line-cable two things happened; 1: I got somewhat electified, I could feel the voltage running thru my arm and maybe leg, and 2: the puffing noise stopped!
    And that concludes the topic: my apartment lacks some kind of good power lining and I have to think of something smart to fix this.
    Any suggestions is nice, but think of this as a log so someone else might get help from it.
    Good long summer to you all!
  • Joey_V
    Review: A comparison of Rotel Integrateds - RA1570 vs RA1592
    by Joey_V
    Introduction:
    This is a comparison between 2 pretty popular integrateds. The Rotel RC1570 has been Rotel's best new series 15 integrated amplifier since their introduction, however, most recently there has been this craze for better and more powerful integrated amplifiers. The days where an...
    05 January 2017, 16:43 Thursday
  • capall
    RA1570 Integ. DAC/Amp vs RC1570 preamp/RB1552 mkII combo
    by capall
    I'm considering the RA1570 Integrated DAC/Amp for a 2 channel setup, and possibly to combine it with a AVR for a 5.1 setup in the future. 2ch though is my main priority. My budget is under $2k and have a pair of B&W 683 speakers
    However, does anyone have any feedback on how...
    26 March 2014, 16:51 Wednesday
  • wettou
    Why Top Quality DAC matter in the SSP-800
    by wettou
    Why Use a Better DAC?
    An argument for why using an external audio converter IC over one integrated on an SoC can help ensure high-quality audio performance.
    By Dafydd Roche, Texas Instruments
    My system-on-chip already has an onboard codec. So why should I bother...
    04 December 2008, 12:37 Thursday
  • revclasse
    Classe CAP 2100 volume noise
    by revclasse
    Recently I bought an used integrated Classe Cap 2100. This weekend, while I was listening at my stereo, when I used the volume, suddenly it went up to maximum for a half second, making a huge noise. This happened for a few times, but just when i used the volume. Also it happened when I...
    02 July 2014, 13:53 Wednesday
  • kpodolski
    CDP-300 "tweak"...
    by kpodolski
    I've owned my CDP-300 for several months and am extremely happy with its performance and sound quality.
    My only issue was with the optical transport. Now, there is nothing wrong with the Teac DV-28SL itself but with some of the "noise" it makes that can be heard from my listening...
    26 February 2012, 13:16 Sunday
