I'd like more power to my speakers.
  • RXDI
    • 5
    I've been out of the game for a year or so and am looking for some guidance on what to do here. I need more power to my speakers.
    I currently have a Onkyo TX-SR706 pushing my B&W's (see sig) and really like the functionality of the receiver and would like to keep it, but it really does not have the power to take the B&W's to their potential.
    Can I just get a separate amp to power the fronts and leave the receiver to power the Center and Rears?
    What would you recommend I do?
    Is it possible to get something worth using for under $300?
    Am I out of my mind and the Onkyo should be enough?
    Again, I'd really like to try and keep the Onkyo to keep costs down.
    B&W DM604S3
    B&W LCR6S2
    B&W LM1
    BIC F12
    Onkyo TX-SR706
    WDTV Live
    Apple TV2
    PS3
  • JeremyG
    • Sep 2008
    • 481
    Well, from the looks of your receiver, it has pre-outs, which is step one. That means you can use a separate two channel amp for your left and right mains. $300 and under pretty much limits you to used gear, especially now that Emotiva appears to have discontinued their UPA-2. You can look at two channel amps on Audiogon, and you may get lucky and find a good one in your price range. Also try the for sale section here. Something may pop up. Good luck.
      Originally posted by RXDI
      Am I out of my mind
      No.
      Yes.
      Meh, maybe?
      1st recommendation: RB1080
      2nd recommendation: See 1st recommendation.
      • RXDI
        • 5
        Thanks guys! I will most likely wait a little longer to save some money and get something better. Most likely something from the Emotiva series.
        B&W DM604S3
        B&W LCR6S2
        B&W LM1
        BIC F12
        Onkyo TX-SR706
        WDTV Live
        Apple TV2
        PS3
        • gimpy
          • 119
          I have the Behringer A500. A good inexpensive option under your budget. YMMV
          • Hammie
            • 304
            He could also join the Emotiva forums and see if anyone if selling an XPA-2 or UPA-2. Either would be a great upgrade to his fronts for his budget.
            Then again, I have Emotiva pushing my system and feel they are great bang for the buck. :T
            Panasonic TC-P65VT30
            Next Upgrade: Cables
