I need help speaker building HT
  • pulsardet
    • Jan 2011
    • 5
    Hi there, I need help for RCL speaker for my HT setup, the current speaker are garbage the sound is flat, the voice are bad, even in 5.1 ou sterio the sound is not good, now that I have money about 500$ to 1000$ budget for RCL speaker, I have allready the wood and tool. What I am seeking, for a WOW effect, when I listen to music I want the hear the voice of the singer or the solo of the guitar, also the hihat, I know that nothing is perfect in this world, but I would like to try to I was thinking about 2 small bookshelf speaker, and center, or a centre with + 2 larger 3 way speaker. Since they is 100000 thing's to look, I include a picture of the room and size, to give a general idea how the system is setup up. I use a Sony STR-DB940 5.1 amp receiver, and darton 300w sub. I have buitl my own microphone and it's a been calibrated also. Any advice is good any good imput are more then welcome.
    Sorry for my bad english, I'll do my best to answer all your comments.
  • madmac
    • Aug 2010
    • 3122
    Hi Pulsardet, I hate to break it to you but your main problem sound wise right now is the Sony receiver. I have auditioned many Sony's over the years and the sound problems you are hearing (" the sound is flat, the voice are bad, even in 5.1 ou stereo") are common with their products. Start with a better receiver and go from there.
    Dan Madden :T
    • pulsardet
      • Jan 2011
      • 5
      Ok no problem, and now what is a good receiver ? Cause that amp was in 2008 a very good and expensive amp still has the receipt of 1200$. But price sometime is not a good indicator.
      • madmac
        • Aug 2010
        • 3122
        If you can afford a little more.....Rotel. If not, try anything other than Sony, like and in order of preference.......Harmon K , Marantz, Yamaha, Denon in the $1K range or more. I have heard that the Pioneer Elite series is very good as well. However, If music is your thing too and you are looking for a musical receiver, then I cannot recommend Rotel enough. I have one and it destroys my speakers!!. Nothing touches it in that price range ($1500-$2000). A VERY musical receiver to say the least!.
        Dan Madden :T
          • 1459
          I guess I'll play Devil's Advocate here - but last time I auditioned a receiver the only things close to sounding as good as a Harman/Karon were a Pioneer Elite and Sony ES. Not saying that the lower-end Sonys have similar sound characteristics, or that my sound preferences match anyone else's, but without knowing the current set of speakers I think it's a stretch to assume the change of receiver is going to do any good. Bad speakers on a Sony aren't going to sound a whole lot different than if they're paired with an expensive Rotel, they'll still sound bad.
          @pulasrdet
          What sort of speakers are you currently using? Manufacturer and model, if possible.
          • pulsardet
            • Jan 2011
            • 5
            Well the speaker that I am using currently is very very bad setup and I know, the centre chanel was on a 250$ kit, and the LR are 1'' tweeter and 10 inch CAR sub.
            Their is a cross over but made by a friend like 10 year ago when he was about 12 lol
            So all the speaker here are junk, I know, since I was curious I borrow speaker from my neigbourg they are not the best about 750$ Energie speaker.
            After a bit of tuning the sound was a lot better, but in sterio cause I had only 2 to test, So was is sure is my weakess link is the speaker itself.
            So Now after a lot of reading here and there, I need littre speaker like bookselft,
            Now I do have to choice, 1 go with a twitter and maybe a 6.5 or 5.5 midrange, or go to go with a 1 Fullrange.
            So I don't know what would be the best out of my 2 option, I have allready a sub that I can setup to play until 80 hz or so maybe lower if best.
            Let me know what you think guy's I am gonna take a lot at the amp also.
              • 1459
              From what you describe I would say your amplifier is fine for the moment - you would benefit more from a decent set of speakers.
              Are you located in America, if not what sources do you have to purchase parts?
              • pulsardet
                • Jan 2011
                • 5
                I am from canada and I was looking to do business with partexpress and madisound. Down were I live their is not much of choice of parts for speaker building, but I allready have the tools the wood and skill, I can solder my cross-over my self, but I have a lot of difficulties to understand how to designt the cross-over itself.
                • pulsardet
                  • Jan 2011
                  • 5
                  Hi after looking at a lot of option I think I'll go with this has my center speaker,
                  So if you have any input on this or what kind of speaker LR I can match to this I am all hears.
                  thank you !
                    • 1459
                    I don't know anything about that center, but personally I would pick your Left/Right speakers first, then worry about getting a center channel up and running.
                    The value offered by the TriTrix speaker kit at Parts-Express is hard to be ignored, though since you say you already have the wood and tools you might save a bit by doing the cabinet yourself....maybe.
                    In any case, it would fit perfectly into your budget and should leave enough left over for a decent center channel and finishing materials. :T
                    Alternatively you could try out the D3's, but I think they run you a bit more (perhaps) and are an aging design. I still think they sound great for movies and bass-heavy, but I'm sure for the price there are a multitude of designs that could better it in certain areas. I'm not certain they'd really give you what you're looking for, though I AM certain they would be far and away better than what you have. Dunno about parts availability though.
                    • madmac
                      • Aug 2010
                      • 3122
                      @technodanvan : agreed about the speakers being paramount. You can hook up a ghetto blaster to good speakers and they'll still sound good. It's just that Sony receivers have no real amp section and produce mediocre sound in most cases except for maybe there super high end stuff. They simply have no 'guts'!!. I was listening to a higher end Yamaha receiver for many years and then changed to Rotel and the difference was to say the least....enormous!. My speakers came alive with transparency and detail and it was truly like hearing all my music again for the first time. If our friend gets new speakers it will help but the Sony will not deliver what is necessary for them to sound good.
                      Dan Madden :T
                        • 1459
                        Agreed, in that both should be replaced someday for a high-quality audio system. However, I believe the biggest gains right now (at least going by what the OP described) would be swapping out the speakers.
                        I won't argue the merits of Rotel and other brands, frankly I have found most moderately expensive receivers (say, $500-$1500) to all sound good in their own right, with H/K sounding the most 'alive'. I do think I tend to prefer a slightly brighter sound than some, which could explain the preference. That said, given separates can be had in that price range I have made the switch. I find Emotiva to be less bright, but it also offers improvements in clarity, soundstage, and of course, power.
                        The best option for receivers, in my opinion, is setting aside a few hours at a large audio dealer listening to your own music, then taking one home for demo purposes. There are many ~$500 (and less!) receivers from relatively mainstream brands (Onkyo, H/K, and Pioneer Elite, to name a few) that sound absolutely excellent in their own right, and to say one should purchase a $1500+ receiver to listen to music/movies is simply more than many would be willing to accept, especially when a price restriction for speakers has already been given.
                          Reference Speaker system in Development
                          Press Release:
                          Arvo Parrot Speaker System,
                          from Lipira Suction Labs
                          It is with great pleasure that we are able to announce the development of the first speaker system by Lipira Suction Labs, the “Arvo Parrot”. Founded as a new development division...
                          01 April 2002, 11:37 Monday
                          Onkyo THX Select Receiver for $800.
                          Wow, I was pretty impressed with this one. Not an Integra product, but Onkyo seems to be putting out a good one with this release:
                          Luke: "Hey, I'm not such a bad pilot myself, you know"...
                          30 July 2003, 01:34 Wednesday
                          Speaker Needs Help!
                          by Johnloudb
                          Well, this speaker, the Nelson/Reed 804B needs help. The midrange has been making noise on occasion for some time. Kind of like the static you get from a worn or bad volume control. I was initially concerned about a rubbing voice coil, but since it comes and goes and sounds like static not rubbing,...
                          25 June 2009, 03:19 Thursday
                          Exploring Common DIY Terminology - Dual Voice Coil (DVC)
                          by technodanvan
                          A dual voice coil (DVC) design is a configuration commonly used in loudspeaker drivers, particularly subwoofers. It involves a speaker driver with two separate voice coils wound on a shared former (the cylindrical structure that holds the voice coils), each connected to its own set of terminals. Each voice coil is wound with its own wire, and they are physically separated but located on the same former. The former is connected to the speaker cone, which moves in
                          18 July 2023, 13:54 Tuesday
                        • rotuuser
                          Input and Speaker Setup
                          by rotuuser
                          I have started having problems with my RSX-1056 input and speaker set-up recently: the settings that I put in (even default input mode) change to some sort of factory defaults repeatedly.
                          My current set-up consists of only 2 front speakers and a subwoofer, and hence I have set all other...
                          08 May 2009, 01:57 Friday
