OK, I own a p.o.s. samsung bdp2500 blu ray player. Also a Sony 5 disc cd/dvd player. Each player is connected to my MX136 Digital Audio Output. HDMI 1.3 connects directly to my t.v. NOT pass through my MX136.
Problem: Whenever I view a movie-Cinema 1 will highlight (Digital Signal) and (Pro LogicIIx). If I choose Cinema 2 will highlight (Digital Signal) and (NEO:6).
(EX,DOLBY DIGITAL, ,DTS,DTS ES) No matter what I try I cannot select any other setting:
Why not? What am I doing wrong. I can understand maybe that decdoing is not in the sony dvd player, but the samsung bdp2500:Product Features
My only possible concusion is I need to plug my hdmi 3 cables into the mx136, then 1 single cable from hdmi out to hdmi t.v. IN.
OR OR OR
Did I connect the wiring corecctly? I was considering to buy an Oppo when it sells or 1 Denon 3800BDCI OR A Panasonic Blu Ray Player. OR my Samsung BD Player
*The salesman said I didnt have the correct codecs to support blu ray or dvd player that recegnized those as choice to play movie playbackmovie
MY BLU RAY BDP200 SUPPORT BELOW,
* Blu-ray Disc format compatible for high-definition movie playback with resolution up to 5 times greater than DVD
* Delivers greatly enhanced video performance with standard DVDs by upconverting their video resolution to HDTV-compliant 720p or 1080p via the HDMI interface and the built-in HQV chip
* Built-in decoders for next-generation Dolby Digital Plus and lossless Dolby TrueHD (7.1-channel)
* Plays BD-ROM, BD-R and BD-RE discs; backward compatible with DVD-R, DVD-RW, DVD-ROM, CD and CD-R/RW discs
* Plays Blu-ray media that can store up to 50GB of high-definition video and audio
* Compatible with VC-1, MPEG2 and H.264 formats
* Built-in Ethernet and USB 2.0 ports for network connection and firmware upgrades
* BD Live support with 1GB of internal memory for game, sub title and special feature updates through the Internet
* 10-bit/108MHz video digital-to-analog (D/A) conversion
* 24-bit/192kHz audio digital-to-analog (D/A)converter
* Enjoy full HD 1080p video output on your 1080p display
* Outputs: 1 component video, 1 composite video, 1 HDMI, 1 stereo audio, 1 optical digital audio, 1 7.1-channel analog output
* HDMI-CEC networking lets you operate compatible HDMI products with a single remote
* Includes remote with batteries and A/V cable
Thank you for your help.
OR OR OR
