Best way to add multiple HDMI devices using RSX-1056
  • rmlmd
    • 4
    Hi Everyone. I am not quite a noob, but know just enough to be dangerous, so am seeking your help...
    I am looking for the best way to combine HDMI video with the best audio quality that I can using my older components. I have an RSX-1056 receiver which I love, despite its lack of HDMI ports. I also have a Samsung DLP TV with only 1 HDMI and 1 DVI port. I would like to add an HDMI splitter box (Monoprice) in order to add a new Apple TV to my TivoHD (which is currently using the HDMI port on my TV and is connected to the Rotel via optical in) and to have more flexibility for adding other stuff in the future. I also have an OPPO 971H DVD player (connected to TV via DVI and to the Rotel via a coax input). The only possible major upgrade I might make in the forseeable future is replacing the OPPO DVD player with the OPPO BDP-93, but probably no time soon.
    My first question is whether to just get a plain HDMI switcher box and leave the audio routed as it currently is, or whether to get an HDMI switcher that also has a TOSlink out and route all of the audio through the one cable.
    My second question involves the best way to connect the DVD player to the 1056. The OPPO has multichannel analog outs that I am not currently using. I know that if I had the OPPO Blue Ray player, using the multichannel output would allow me to take advantage of the newer HD sound formats--Is there any advantage to doing this now with my DVD player?
    Thanks for any input.
  • madmac
    • Aug 2010
    • 3122
    Do not use the analog multi outs on the Oppo dvd (Unless you need SACD and DVD audio playback). I have the same one and the audio is not great. Let the Rotel decode the sound out of the Oppo via the coax. Other than that, I would get a HDMI switcher personally. When you get the Oppo BD player, THEN you can connect the analog out's the the Rotel and get the hi def codecs (ie..DTS-HD).
    Dan Madden :T
    • rmlmd
      • 4
      Thanks, madmac, that is very helpful!
      • Craig Simon
        C1, Oppo and HDMI Switching
        by Craig Simon
        I am a complete novice (maybe even an idiot :-) ) when it comes to component and interface control. I have a Halo C1 and have just purchased an Oppo HDMI switcher. I understand the C1 will switch the outputs of the Parasound Zhd but given the Oppo has a 232 port can it be made to do the same or was...
        03 December 2007, 21:48 Monday
      • wildpanda86
        HDMI switcher that plays nice with my Rotel?
        by wildpanda86
        I'm in need of an HDMI switcher that works well with my RSX 1550.
        I've got all my HDMI ports used up and need to share my xbox 360 and ps3 on the same port.
        I tried a mono price switcher in the past and with the xbox I couldn't get the full resolution outputed and the ps3...
        29 June 2011, 00:42 Wednesday
        New info on Zhd HDMI switcher and Zbreeze cooling fans on Parasound website
        Take a look... new info just popped up on the Parasound website for the new Zhd HDMI switcher and the Zbreeze cooling fan. Pictures, manuals, and brochures.
        www.parasound.com (click on the Z Custom section)
        Interesting that the Zpre2 still does not have any official pictures...
        23 February 2006, 09:31 Thursday
      • wettou
        Classé Blu Ray Player
        by wettou
        Here is why Classé will not do a blu ray player, they don't want to rip off their customers
        Oppo on the Inside, Lexicon on the Outside
        by Clint DeBoer — last modified January 15, 2010
        16 January 2010, 23:26 Saturday
      • markyboy56
        best 5in1 hdmi splitter
        by markyboy56
        hi
        i am after buying a 5 in1out hdmi splitter with the very latest specs
        ★4K ULTRA HD 5 IN1 OUT: This HDMI Switch connects up to 5 UHD HDMI sources on a single display and easily switchs between 5 sources. Support bandwidth 18Gps/600MHZ, HDCP 2.2, 4K 60HZ 4:4:4, FullHD,...
        09 March 2018, 12:29 Friday
