I picked up a used RX-V1000 recently. I was looking for a new receiver that had at least 5.1 preouts, a little more headroom than I had previously had, and the capability to safely drive down below 8ohms. This Yammy really seemed to fit the bill. Unfortunately it took a bit of a bump in transit. So, when I turned it on for the first time and hooked up my 8-ohm Tritrix MTMs to it, it shut down when it got to -55db. I was quite dismayed, and per the manual, checked that all my speaker wire connections were not crossed or shorted. Everything looked good, so as a check I tried hooking up to the "B" main speaker outputs. They worked great, as did the center and rear surrounds. Watched Wall-E last night, nice and loud and it sounded great... but I still want my "A" mains. Any ideas or similar circumstances?
RX-V1000 Receiver Problem
Most likely, when transported, something came loose and is shorting out inside the unit. Only way to know is to open it up and look around. You might be out of luck and have to just continue with the B posts to use it. The A and B serve no real difference than to sets of posts for passive bi-amping or connecting two different sets of speakers (like in another room that you only play with music).Digital Audio makes me Happy.
-Dan- Bottom
by brodricjIf anyone out there in Club Parasound has some surplus HRA3's (rack ears suitable for 3RU high Halo gear), I'm in need of 3 sets. Please PM details to me for easy sale. Thanks!-
Channel: Club Halo/Parasound
15 May 2009, 07:37 Friday -
by Chris DI've bought a couple TV shows on DVD that I currently enjoy, like Heroes, Chuck, and Family Guy. I haven't been too attracted to buying other shows on DVD, though.
For kicks, I added "Quantum Leap" to my holiday wish list, and people bought the first 2 seasons for me, so I'll...-
Channel: At The Movies and on TV
by oldskoolHello all,
I have a Yamaha RXV1000 reciever which I moved into a server rack in my basement with all my other components and is no longer visible or easily acessible. Its an older unit without hdmi, only composite, s-vid and component output. I have it connected to a new toshiba...-
by EliavHi guys
the sensitivity on the 803s and the 802d is reportedly the same (~ 90dB), yet, I can definitely say that my comfort listening loudness has changed from 55dB with the 803s (classe cp700 stereo pre amp dial) to about 58-60dB with the 802d. same amplification and cables ( all balanced...-
Channel: Club B & W Speakers
by Andrew PrattNo sex please, we're Yanks
Censors don't allow adults to enjoy doing it
By LOUIS B. HOBSON -- Calgary Sun
HOLLYWOOD -- Urgent message for James Bond.
If you come to America, you'll be allowed to have sex but don't you dare enjoy it.
That's the... - Loading...
- No more items.
