In Wall vs. On Wall vs. In Room Information / Help
  • cray54
    • 7
    I’m looking resources that would help explain the audio benefits, drawbacks and compromises associated with speaker location in regards to in wall, on wall, near wall, and in room. I’m sure there are many other variables associated, but that is something I’m particularly interested in learning.
    Can anyone recommend a good resource, website, thread etc?
  • cray54
    • 7
    Maybe just a brief explanation?
    • krips
      • 264
      I can't offer much information, but I believe that the closer a speaker is placed to the wall, the more 'boost' it will get in the bass region, as if it has a wider baffle, which could mean that you don't need BSC...?
      Sharp LC-42D64U
      TriTrix MTM (Sealed)
      • Blindamood
        • Sep 2003
        • 900
        I just installed a pair of B&W in-wall speakers (CWM-650) in our bedroom, after mounting the lcd tv on the wall as well. I listened to them prior to mounting and they sounded great, short of the bass support that the wall will provide. Unfortunately, my integrated amp died, and I have not been able to test post-installation! New amp arriving tomorrow, so I cannot wait to try them out.
        For me it was mostly aesthetics that made the decision. Looks cleaner, and opens up space on the dresser surface below the tv/speakers. I installed speaker terminals on the lower part of the wall below the speakers, so that I can plug them into the amp when it arrives (i.e., no permanent connection).
        Fortunately, the install of both the tv and the speakers went smoothly last weekend. You have to make sure, however, that nothing will impede the wall space required by the speakers. And, of course, they're much harder to move if you change your mind! So, there are more dependencies for in-wall, I believe.
        Brad
        • htsteve
          • 1216
          Chris,
          I'll hunt around to see if there is anything more formal on this topic (other than the link below). Meanwhile, I'll share some thoughts based on my experience and what I've read/heard along the way. I've had both on wall and in room speakers. Currently my four corner speakers are floorstanders and my center sits on an entertainment center.
          * I tend to agree that speakers get reinforced bass as they are closer to a wall, particularly in corners. This can be a relatively good thing, like having book shelf speakers (especially as rear speakers).
          * For front bookshelf and floor standing speakers, having them close to a wall might box them in acoustically. I've found that the more air you give the mains, the better. I have B&W 802D's as my mains. They are around two feet off the rear wall and about 1.5 feet off the side wall in an HT room. In the prior room they were in, they were closer to the wall and were more compressed sounding.
          * Same issue for a center channel. You want to give it air, especially since so much dialog comes out of the center. Putting in a cabinet maybe the only option. However, if you can give it air, that is good.
          * Speaker height. I've found that for critical listening, the tweeter height needs to be as close to the ear position as possible. This applies for all speakers. If you use on-wall or inwall, keep this in mind. If they are above the listening position, the integration between listener and speakers is lessened (IMO).
          This is not to say that it wouldn't sound great with good equipment, but I've found that when they are closest to the ear height wise, the better.
          * In wall. I have considered in wall at times. The problem I recall with these is that the box to hold the speaker needs to be quite rigid 9to prevent unwanted vibrations from smearing the audio). Back when I looked, the inwall solutions weren't very appealing. However, I believe companies like B&W now have a whole range of in wall speakers and rigid boxes (especially for new construction). I believe that some of the their in-wall speakers have directional drivers that create a larger soundfield. These would be best suited for rear speakers (see below).
          * Rear speakers. I've had on wall and free standing speakers for rear speakers. I prefer on floor rear speakers physically behind the listening position. This has been the best overall surround experience I've had.
          However, cost, WAF and other issues may force you to look at other options. One area that is discusses is dipole or non-dipole speakers. My take is that if you can't put speakers behind you, then on the sides works next best. If you are in this situation, I prefer direct (monpole) speakers, preferably pointed at the listener. But if one has a large area to fill, dipoles are a good option. They definitely create a substantial soundfield ( I used triangular dipoles for years), but often at a cost of detail and dynamics (IMO).
          I've recently built a dedicated HT room where I was able to implement these concepts. The end result has been spectacular.
          Here is a reference I found.
          I'm sure others will chime in. Hope this helps.
          • kgveteran
            • 865
            I've had stand mounted rear surrounds and wall mounted. I just recently built a modified design from Mark K. that worked out great. They are comprised of a Dayton RS28a and a RS225 (tweeter/woofer).
            I cross them over at 100hz, so bass isn't really an issue. I use a Denon receiver and the Audyssey room correction probably took care of what ever boost they may has gotten from close wall proximity.
            They sound great and the price was right.Here's a link to the thread with some pics on page two. I have always found inwall to be inferior to on wall unless you spend enough money like the B&W mentioned. The more you spend on inwalls the more you are likely to get builtin EQ dip switches that will help correct boost issues and standing waves.
            Good luck.
            • cray54
              In Wall vs. On Wall vs. Away From Wall
              by cray54
              I'd like to learn more about the benefits / drawbacks of in-wall, on-wall and away from wall speaker design and mounting. I have tried to find good information but tend to only find bits and pieces.
              I'd like suggestions for good books, online documents or threads that would help....
              06 February 2009, 01:46 Friday
            • kjgarrison
              In wall speaker install and enclosure
              by kjgarrison
              Hello everybody. Love this site, btw. I just spent an hour looking for something similar enough to my situation. No luck, so here goes.
              gawd... I just looked at this and it is waaaay too long ...
              I have an "entertainment center" that I hope to install in-wall...
              29 March 2008, 15:00 Saturday
            • Dannyh
              Complex! in-wall/behind screen design questions
              by Dannyh
              Please help a beginner with options and/or advise for a unique and complex setup.
              Background / design goals:
              I have a formal living room that will serve as a home theater when not entertaining so my design goals are listed in order of importance.
              1. Hide...
              21 December 2005, 22:42 Wednesday
            • belzarrath
              Beginning my HT planning (wall Panels)
              by belzarrath
              I'm surprized that I could not find more information of DIY acoustical panels.
              I noticed that many Ht rooms have upholstered walls. I looked at the price of these wall systems and designs, and I've got to say they seem to high for me.
              Can't a person simply buy 5/8" x 4' x...
              23 May 2008, 01:30 Friday
            • cngbrick
              Recommended on-wall build to match IB sub
              by cngbrick
              Good day gents!
              I have been lurking for some time and sorting through the many impressive build threads on this site. I'm impressed with the quality of the information and general tone of the discussions.
              This said, I am looking for some recommendations for an on-wall build...
              16 March 2011, 11:50 Wednesday
