Need some advice in tackling a loudness issue
  • george_k
    • Jan 2004
    • 342
    I have a bit of a problem with my current setup.
    When I watch a movie be it a DVD, Blu-Ray or a sattelite feed I find that I need to crank up the volume pretty high (i.e. volume knob is at about 82-85% of max setting) to hear the dialog clearly and easily.
    At that volume level I get worried when things like loud bangs and explosions start happening, I'm worried that my amp will clip and mess up my speakers.
    My current setup has no sub, my sub is sitting at my parents place across the country. If I were to add the sub and set the rest of my speakers to "small" would that lessen the chance of damaging my speakers during loud passages?
    Other alternatives I've been considering are to add an external power amp or upgrade to a more powerful receiver but even at 150w per channel I'd only be gaining ~5dB of headroom...is that enough?
    Receiver:
    NAD t742 (50wx5)
    Source components:
    ExpressVu Satellite
    PS3 (for DVD/Blu-ray playback)
    Speakers:
    B&W 603/S3 mains
    B&W LCR60 center
    Paradigm Micro Surrounds
    Paradigm Servo-15 (missing in action)
  • Russ L
    • 544
    I have the same issue on my Rotel RSX-1057 Reciever and all other surround systems as well. Its normal and due to the dynamic range. Its harder to hear the dialogue due to the dynamic range of surround formats. I have a max. setting(Normal) where its harder to hear the dialogue relative to the other sound. A Med. and a Min. dynamic range setting where the frequency range is reduced and the dialogue is boosted. Do you have these settings? I think setting your speakers to small and adding a sub will only prevent extra bass and not boost dialogue. More power per channel will boost both dialogue and other frequency ranges as well. Your speakers should be able to handle the volume (EDIT: I see you are using 50W/Ch so this might be an issue although I have 75/Ch and sometimes to hear the dialogue I have to have my reciever running at 70-75% vol)if you don't have the dynamic range setting which is great at night when you want to hear the dialogue but don't want massive explosions waking up the neighbours. 8O Best regards, Russ
    Russ
    • Russ L
      • 544
      You could also try boosting setting for the volume for your center channel. If worse comes to worse upgrade your LCR 60 to a LCR 600 to boost the dialogue relative to the left and right 603s. Or get a reciever with dynamic range settings. The low dialogue vis-a-vis the other sound is one of the drawbacks in having great movie sound. I see you are in Canada and with the 600S3 series being phased out there are great specials still available right now. -Russ
      Russ
      • george_k
        • Jan 2004
        • 342
        My receiver does have a dynamic range setting but I only use it at night otherwise it takes away from the experience I find.
        I've already boosted the center channel volume setting by +2dB to match my mains using a SPL meter and a sweeping pink noise test.
        I thought of getting the LCR 600 but it just doesn't fit in my stand, that's why I went with the 60 (was a huge improvement over having no center at all)
        • servicetech
          • 212
          Upgrading the center channel helped a LOT when we had this same problem. Our little JBL center channel didn't seem to keep up no matter what we set the center level at. A new Dayton center channel with 2 6.5" woofers and a soft dome tweeter (home made, see DIY mission possible section) really cleared things up.
          • Russ L
            • 544
            It might be a problem with room acoustics. Poor room acoustics can often make dialogue muffled. Acoustic panel treatments might make the voice more audible. Try Sonex UNX-2 Classic. I have 8-2" by 2' by 4' in my setup. About $250. Regards, Russ
            Russ
            • Kal Rubinson
              • 2109
              System calibration, setup and room acoustics are the most common causes of this problem.
              Kal
              Kal Rubinson
              "Music in the Round"
              • Fred333
                • 45
                Yea I would look for a separate volume control that can maintain a constant volume not matter what level it comes in at. I know my brother -in law has one. I think he got it online some where.
                Always looking for a Scranton Web Design company.
                • tina
                  Speaker volume not as loud as it used to be
                  My mom was dusting around the theatre system one day, and I'm not sure what happened but now for some reason whenever I watch TV or anything, I need the volume to be as high as 70 to hear anything. It's odd because if I turn on the radio through my theatre, the volume is still quite regular. I'm not sure what the issue could be or which wire is loose but I could really use some help. I have an Integra THX surround EX receiver and an Integra WRAT ADM 2.1 Amp. I also have a motorola digital TV box hooked up to the system. If anyone has any ideas I would appreciate it. Thank you
                  Tina
                  • Hyenna
                    Dynamic range ... Stuck?
                    by Hyenna
                    I'm fresh out of ideas to solve my problem...
                    I bough a new 1066 and it sounds like the "Dynamic Range" option is always engaged.
                    Here is why I think so :
                    1) Dolby soundtracks lack dynamics, DTS ones do not
                    2) My old Yamaha receiver doesn't lack any dynamics...
                    11 October 2003, 13:54 Saturday
                  • krek
                    service menu dynamic brightness Samsung
                    by krek
                    Hi everyone,
                    Since a couple of weeks, I am the proud owner of a Samsung Plasma, ps58B680.
                    The screen has only one flaw which is somewhat disturbing, which can best be described as a flickering of the brightness, in some dark movie scenes. I can even pause the dvd when it...
                    08 February 2010, 13:49 Monday
                  • Nolan B
                    dynamic range control with 1068
                    by Nolan B
                    I noticed on the rotel site for the description of the 1068 it says it has dynamic range control... "Advanced microprocessors from Crystal Semiconductor handle Dolby Digital (complete with dynamic range adjustments)"
                    Am i blind? Why cant i find the settings in the OSD that let...
                    26 October 2006, 18:59 Thursday
                  • grit
                    dynamic range control question
                    by grit
                    On my Rotel 1560, there are 4 settings for Dynamic Range Control (for Dolby Digital, True HD, etc). Min, Mid, Max, and Auto.
                    What does "auto" do??
                    Max means no dynamic range compression, correct?
                    I get how dynamic range control works, but aut...
                    20 June 2011, 17:24 Monday
                    Marantz 8801 - setting expectations?
                    When I got the email with Trond-Erik's new Pro-Pro, something about that rang a bell. The bell was related to an AV Forums post by a guy with high sensitivity speakers comparing the Benchmark AHB2 amplifier and the M22 and some other amplifiers. One of his bugaboos was output noise, and noise that could...
                    31 December 2015, 12:40 Thursday
