Separate Circuits For A/v Equipment?
  • Parsonsk
    • 101
    I'm in the process of wiring the basement for the home theater and wanted to provide a designated 20 amp circuit for the audio and video equipment.
    What should i include on a circuit - do i mix A/V equipment and lighting and the sub or leave it just A/V and sub but not lights or do i put the sub on the circuit with the lights? do i mix the tv with the equipment or with the lights????
    aaaggghhh
    What do i include and what do i put on a different circuit?
  • mitch57
    • 429
    I would go with two dedicated 20 amp circuits. That's what I did because the electrician said it costs about the same to run two as it does to run one. Then you can split it as you see fit and still have two dedicated circuits for your entire home theater without fear of overloading the circuits.
    Mitch
    :stupidpc:
    • Parsonsk
      • 101
      i guess the question should be what pieces of equipment should i put on each circuit regardless of weather its a 15 or 20 amp
      Is it best to separate the audio from video from lights from sub???
      • mitch57
        • 429
        I would seperate the lights and sub from the rest of the system. If you have two dedicated 20 amp circuits in addition to another 15 or 20 amp circuit that currently existed in your basement I would connect all your lights to the existing circuit. Then I would split my video on one of the "New" dedicated 20 amp circuits and your audio components on the other. You could also put the subs with the rest of the audio components if you like. But I would definitely put your lights on a different circuit as they can introduce noise into your system.
        Mitch
        :stupidpc:
          My understanding is that all your A/V equipment (including the sub) should be on the same circuit, and only your A/V equipment should be on that circuit.
          • Glen B
            • 1106
            A/V equipment can be on separate circuits, however those circuits should all be on the same 120V leg.
            • schnauser
              yes, keep the lights on a "lighting circuit" and put all your gear on one or two 20 amp circuits dedicated just for that. it doesn't matter one iota how you mix and match your gear on each circuit, all that matters is that you calculate how many amps each piece of gear is drawing, and keep the total to under 20 for each circuit. then crank it up, if you don't trip a breaker testing at a really really loud volume, your done. tripping a breaker is annoying, but it won't hurt anything.
              • Pookie007
                • 212
                When you calculate your circuit load, remember a 20A circuit will trip at 16A (80%). When designing, I don't load a circuit past 14A. If you are running dedicated circuits, these should be for your HT system only. The lighting can be on a non-dedicated circuit with other household stuff. You won't gain anything by putting it on the same circuit. A dedicated lighting circuit won't give you better light.
                The reason they said it is the most cost effective to pull 2 circuits is conduit loading. If you pull one, you have unused space in the conduit. If you pull 3, you have to up size the conduit.
                When separating the loads, I would just try and balance them. I would find the two biggest draws and put one on each circuit and then fill in the remaining space with the other components. When you pull the circuits, I would get oversized dedicated neutrals and pull an additional ground conductor with each circuit. This will eliminate the concern about your circuits all coming from the same leg. If you do connect to different phases it won't be a problem. The transformer inside the equipment converts it to DC and that is what the gear runs on. If you were trying to match phase angles for closed transitions or spin a 3-phase motor the right direction, I would be concerned about the phase you circuit is on. Short of that, it isn't an issue. Most homes only have 2 of the 3 phases available on the pole wired to their house.
                Back to the original post, if you are wiring the basement now, is the drywall off? If that is the case, you can wire the outlets with Romex cheap. I would look at how much space I had in the breaker box and pull the 2 I need and see if I could squeeze a spare our two circuit while I was at it. Proper grounding will solve a lot of your problems. This includes bonding the grounds to the conduits and back boxes (if metal). You also could change the panel in your basement to a 200% neutral if you want to go wild. I could do this all night.
                • BKSinAZ
                  Possible reasons why the Protection lights came on in the front of the RMB-1095 and stayed on?
                  by BKSinAZ
                  After I finished watching a movie I forgot to shut off the stereo system and TV. I went out of the house for about 2 hours. When I came back I decided to watch another movie. As I walked up to the RMB-1095, I noticed all 5 of the protection circuit lights on the front panel were on and were staying...
                  13 January 2004, 08:45 Tuesday
                  Coming soon: The Chris D Home Theater, Name yet to be Announced
                  I'll hold on to the name that I'm going to use for my theater until it's complete.
                  I'm posting some pictures and info about my theater construction at the request of others here on the Guide. I thought someone might be interested to see this stuff. If you'd like to hear more, I'm showing...
                  15 February 2004, 01:45 Sunday
                • SpOoNmAn
                  Amps(Rotel) and dedicated circuits..
                  by SpOoNmAn
                  Some of this has to do with Rotel so I'll post this in here as well. I also posted this in the Home Theatre forum here....
                  I have 2 dedicated circuits running into my livingroom, a 15, and 20amp lines.
                  Now...I recently bought a BrickWall High Current surge protector from...
                  03 October 2003, 14:36 Friday
                • SpOoNmAn
                  Amps and dedicated circuits..
                  by SpOoNmAn
                  Some of this has to do with Rotel so I might post this in Rotel Club as well...
                  Now...I recently bought a BrickWall High Current surge protector from a member here. It is specifically for amplifiers...
                  03 October 2003, 14:34 Friday
                • Rolyasm
                  Remote amps with multi circuits?
                  by Rolyasm
                  I am looking to put some pro amps through a wall behind my home theater components, into another room where they will be out of reach, out of sound. I hear some people say that you have to turn these pro amps on and off, manually, every time. I may also be running some extra dedicated 20 Amp circuits...
                  27 August 2006, 17:25 Sunday
