Remote amps with multi circuits?
  • Rolyasm
    • 382
    I am looking to put some pro amps through a wall behind my home theater components, into another room where they will be out of reach, out of sound. I hear some people say that you have to turn these pro amps on and off, manually, every time. I may also be running some extra dedicated 20 Amp circuits to the cold storage, where my amps will be. Any ideas on how I can connect the amps remotely, use a few plugs so I don't have all the amps on one circuit, and have some kind of sequence to turning them on and off. Thomas mentioned this product, but not sure how it will work.
    If I use something like this, I imagine I plug it into one plug, and then all the amps will be running off of the one circuit that the Furman is plugged into. Not exactly what I want. Any ideas are appreciated.
    Roly
    • Rolyasm
      • 382
      Thanks Thomas,
      You the man.
      • Glen B
        • 1106
        Originally posted by Rolyasm
        Thanks Thomas,
        You the man.
        So how come I didn't get a "you da man" too on AVS Forum [snif, snif] ? I recommended the same Furman products to you there.
        • Paul H
          • 904
          http://avsforum.com/avs-vb/showthrea...53#post8306853
          Because Thomas has been patiently answering his questions starting a year ago "what's a woofer?" to now when Rolyasm is helping set up friends subs with laptops, measurement mics and eq software. :twisted: :B
          • jimmyp58
            New Multi-Channel Amp soon to be released
            by jimmyp58
            Anthem will soon release their new standard series amplifier, the Statement P5. Originally, the company planned to release this amp as part of their new standard series release featuring the D1 pre-pro as well as the P2 which is the 2-channel amp version of the P5. The company is experiencing some unforeseen...
            07 November 2003, 06:53 Friday
          • SpOoNmAn
            Amps(Rotel) and dedicated circuits..
            by SpOoNmAn
            Some of this has to do with Rotel so I'll post this in here as well. I also posted this in the Home Theatre forum here....
            I have 2 dedicated circuits running into my livingroom, a 15, and 20amp lines.
            Now...I recently bought a BrickWall High Current surge protector from...
            03 October 2003, 14:36 Friday
          • SpOoNmAn
            Amps and dedicated circuits..
            by SpOoNmAn
            Some of this has to do with Rotel so I might post this in Rotel Club as well...
            Now...I recently bought a BrickWall High Current surge protector from a member here. It is specifically for amplifiers...
            03 October 2003, 14:34 Friday
          • EAmin
            20A dedicated circuits in my HT
            by EAmin
            I'm looking into putting in several dedicated 20A circuits. I need some help deciding how many dedicated circuits I need. I will have 4 amps including 2 sub amplifiers --- see below.
            (1) Rotel RB-1090: 380 X 2, Power Consumption: 800 Watts
            (1) Rotel RMB-1095: 200 X 5 Power Consumption:...
            23 February 2005, 21:38 Wednesday
          • Parsonsk
            Separate Circuits For A/v Equipment?
            by Parsonsk
            I'm in the process of wiring the basement for the home theater and wanted to provide a designated 20 amp circuit for the audio and video equipment.
            What should i include on a circuit - do i mix A/V equipment and lighting and the sub or leave it just A/V and sub but not lights or do i put the...
            10 May 2007, 09:03 Thursday
