I have a Marantz SR5600. A while ago I posted about my receiver having troubles; turned out it was my fault. The receiver has been fine for a couple of months. I took it home over winter break, had it hooked up for a night and it ran perfectly, brought it back when moving in after break, and I have some issues. I don't know how moving it could have caused any of this--I packed it in the original box & styrofoam and took great care to be gentle with it.
Here are the problems:
On TV input, I have to turn it up to -11 to be loud enough to be audible. Usually I listen on -29 or so.
On DVD input, the quieter volume ranges have no effect on volume levels. -67 sounds the same as -41. This is until I get to around -31 or so; it starts to be affected in this range. Very odd and annoying.
With my iPod input (3.5 mm split into RCA) I get no sound from the main speakers. I only get sound when I put it on something like a Dolby mode. When I do that, I only get sound from the center channel; never anything from left or right speakers.
Pretty odd and pretty frustrating. I can't notice that the sound has changed at all and it still can be plenty loud. I e-mailed Marantz yesterday and am hoping to hear back soon. I may end up calling them. Everything is hooked up well and identical to how it was before. Anyone have any idea what is causing this? Anything I can do beyond sending it in for service?
