I have a small room 12 X 12, and want to add a subwoofer to my 2 channel setup. The choice is between Velodyne dd-12, Sunfire True Subwoofer EQ, and the B & W asw 825. Please comment. My listening is 75% HT
Subwoofer with B & W 804s.
Tags: None
Wow!
I would not have thought that would be the reply...
(I guess I better go listen to that thing one more time)
8)- Bottom
OK,
My resonining is as follows: Small room, small sub with lots of go. And let me re-phrase to say tha that I have had good like with the same Sunfire sub. Considering the room size it does seem like a good choice althought you might want to strack a few cinder blocks on it :-).- Bottom
I really like my DD-12, but my room is 24x14. I don't know how much of a difference that make with the auto eq function on the Velodyne, but it out performed the ML Depth in my room. I think part of the performance gain is from proper set up. The auto function is much better than my skills.- Bottom
