receiver + amp still better than pre/pro + amp?
  • CPALIU
    • 58
    Why would using a pre/pro + amp still deliver "better" sound quality than a receiver + amp? If a amp was connected to a receiver, wouldn't the onboard amp on the receiver basically be disabled? if this is the case why is it still better to use a dedicated pre/pro than a receiver?
  • htsteve
    • 1216
    Quality of Pre-Amp
    CPALIU,
    The short answer is that a dedicated pre-amp generally is much more capable than a receivers pre-amp. Recall that a receiver is generally made up of three things: pre-amp, amp and tuner. A dedicated pre-amp is just a pre-amp (almost all of the time). You can buy a $600-$1000 receiver that has a fairly good pre-amp section. Most HT pre-amps begin at $1000 and go up. The quality of part, processors, power supplies, etc. in an HT pre-amp are simply better than most receivers. Also, pre-amp's often are more configurable than receivers (i.e. bass management, individual speaker configuration, settings by input, etc.). In my opinion, you need to spend $2500 and often more to get a receiver that has a pre-amp section close in performance to a dedicated pre-amp. At those dollars, you can get quality separates.
    As to using a reciever and an outboard amp, that is almost always better than just the receiver alone. I don't know if the receiver amps are 'disabled'. I think they are simply not used. Some recievers allow you to use an outboard amp and then assign some 2 amp channels to a second zone. The Rotel RSX-1057 does this.
    Also, by going to separates, you spend more now but potentially less later. Let's say Dolby Digital HD is out and you ant that capability. If you buy another receiver with DD-HD (for the pre-amp section), you are also rebuying the amp and tuner with it. If you have these pieces individually, you only buy what you need. In theory, it saves money in the long run.
    Hope this helps.
    • Chicagohonda
      Receiver/AMP Advice for DM603S3/LCR600 speakers
      by Chicagohonda
      Hello -
      I am new to this board and new to the world of mid-level audiophile systems. I am hoping for some sound advice on a receiver/amp purchase as my Yamaha RV-1105 finally gave out after 9 years of use.
      I originally purchased B&W's Mini-Theater system and was not...
      21 March 2007, 10:33 Wednesday
    • BeeBop
      RX-1050 Stereo Receiver Pre-Outs
      by BeeBop
      I am posting this to the forum instead of trying Rotel tech support in case the answer is useful to someone else.
      I am a 2 channel kind of guy and will be for some time to come. I have a RX-1050 Stereo Receiver (100wX2) that I like a lot . I am thinking of getting another amp and using...
      07 December 2003, 06:24 Sunday
    • bkaushansky
      Help me spend $1800 on rec/amp
      by bkaushansky
      I need to replace a Pioneer elite rec with something new. Looking to spend $1800 tops. I can either go with an integrated receiver/amp or separates. Installation is in an equipment closet mounted rack. I am driving Paradigm 60 Studio Reference front channels and Paradigm Studio Ref cc-570 center....
      30 November 2007, 10:34 Friday
    • specialized
      803S optimal Amp/Preamp.
      by specialized
      Hi there.. I decided to do the final update about my system.
      In this moment i have 803s/HTM3S/CM1 combination driven by Denon 3808 as Pre/Pro, and Rotel RB-1080 for fronts.
      I realized that i listen music 95% and only 5% HT (if i knew it this i would made just stereo )....
      28 February 2009, 02:59 Saturday
    • FJD6523
      Denon 3805 as Pre Processor & Available Options
      by FJD6523
      :P This is my first post so thank you for your patience.
      I have decided to go forward with adding 5.1 to my main system and have pulled together all my equipment with an idea. I have an uncompromised 2 channel setup and am going to use my Denon 3805 and dvd-2910 taken from the other...
      20 April 2008, 21:15 Sunday
