Doubling speakers by using amp AND reciever channels
  • Rolyasm
    • 382
    I know this probably wouldn't sound good, but I was curious about this setup. Say a person was using a Receiver as a preamp and had a 5 channel amp for 5.1. So all 5 speakers are running off the amp. Is there a way to use the amp channels, AND the receiver channels. So lets say you have a typical 5.1 on the amps, then you added another center, two more fronts and sides, and mabye even rear surrouds running off the receivers power. Can you run the receiver as a preamp and also use it's amp capabilities? I know it would be difficult to calbrate and probably do much more harm than good, but is it possible?
    Roly
    Twin Moderator Emeritus
    • 16706
    The closest I can even come to recommending something like that is biamping with the amps from the different units to the single set of speakers.
    Running additional spealers would cause so many problems it's not even funny.
    • Azeke
      • Mar 2003
      • 2123
      Indeed, that seems that would cause impendance issues, which in turn, may cause some serious electrical damage to your equipment.
      • Kevin P
        • 10812
        It shouldn't damage your equipment, since the pre-outs are always active whether or not you're using them, and whether or not you have speakers connected to the receiver's speaker outputs. However, having more than one speaker per channel isn't going to sound good. The biamping idea would work, but since most outboard amps are far superior to those built into receivers, it would more likely degrade the sound over using the outboard amp alone.
        • Azeke
          • Mar 2003
          • 2123
          Thanks Kevin I mispoke, I thought he was going to run some additional channels (other than 5.1) off the receiver.
          Azeke
          • Karma
            • 801
            HI Roly,
            If I understand your question, it should work fine. All you need to avoid is somehow connecting your amp outputs to your receivers power amp outputs. That will make smoke! The receiver doesn't know if you have something hooked up to the preamp outputs. They remain active at all times.
            It's another question as to whether you should do it. One possible application would be a complete 5.1 system in another room but running off one set of electronics. Is that what you have in mind?
            Be very careful here. Make sure we understand your question.
            Sparky
            • Rolyasm
              • 382
              It is more hypothetical. I was talking to a guy who has a 5 channel Earthuake amp, but wants to use the extra, unused channels on his receiver to add more speakers. He would end up having like a 10.1. I thought it would be very difficult to calibrate the speakers to sound good, but I was uncertain about the "fry" possiblitly of his equipment. So it sounds like he can't hurt his equipment as long as the preamps go to the amp, the amp to the speakers, and the output channels on the receiver to more speakers. He might try another center for fun. I am not sure. I just didn't want to see him blow his gear. Thanks all.
              Roly
                • 16706
                Again, multiple speakers playing the same thing in the same room (ie: two centres) will sound HORRIBLE :nonod:
                • methril
                  RSX-1067 Zone Channels as Sub Amp for Gallo Ref3's?
                  by methril
                  I'm having a tough time finding a quality crossover to filter the full range line-level signal from my receiver's pre-outs prior to running them through a separate 2-channel amp (NAD C370) to power the 2nd set of subwoofer voice coils on my Gallo Reference 3's. Guess I'll just have to wait for the Gallo...
                  06 July 2005, 01:29 Wednesday
                • Rolyasm
                  4 Side channels from 2 amp channels?
                  by Rolyasm
                  In a larger room with 2 rows of seating, is it possible to either split the Surround Output to four channels of amplification (four RCA instead of two with a "y" splitter) or to run four pair of speaker cable from 2 channels of amplification (LSurround amp out goes to 2 speakers and RSurround...
                  05 October 2006, 09:29 Thursday
                • Whozit
                  Want to try passive bi-amp
                  by Whozit
                  I have a 1066 pre/pro and 1075 amp that are temporarily driving a pure 2 channel system with Paradigm Studio 100v.3. Since I have some spare channels on the amp, I thought I would play around with bi-amping the 100s to see if it made any difference. My question is how do i get the front L/R signal...
                  25 January 2006, 23:18 Wednesday
                • nick.h
                  RMB-1095 - Bi Amp???
                  by nick.h
                  Im in the process of purchasing a RMB-1095 for my B&W 803D and HTM2D. Was wondering if I could bi-amp the fronts with the spare 2 channels.
                  As the amp doesn't support this, I was thinking of using a RCA from my processor and splits into 2 plugs, providing the ability...
                  22 February 2007, 23:35 Thursday
                • JohnAng
                  Amp question - Arcam or Rotel for my 804 5.1 system
                  by JohnAng
                  I am looking at purchasing
                  B&W 804s fronts
                  B&W HTM4 cetre
                  B&W 705 rears
                  B&W ASW750 sub
                  i listened to this setup with an Arcam AVR300 amp
                  and Arcam DV79 dvd player
                  I realy liked the sound in 2 channel mode and since i won't be...
                  07 September 2005, 21:42 Wednesday
