Denon 3910 Test Tone Issue
  • Hoopofficial
    • 44
    I was trying to recalibrate my Denon 3910 but the test tones are not constant. They Buzz, stop, Buzz, stop etc.. Has anyone else experienced this issue. I do have the most recent firmware upgrade. Test tones worked before I installed the "upgrade" but I installed it months ago and never re-checked the test tone generator. Hence, I don't know if there is a cause and effect relationship. Any help will be much appreciated. thanks.
  • Aussie Geoff
    Sub Test Tone Level (should be) Fixed in RSP-1098 Upgrade
    by Aussie Geoff
    It was suggested to me by one of my sources that the DSP EPROM update in the latest RSP-1098 firmware release (plus the native EPROM code in the RSP-1068 and RSX-1067) fixed the issue that many of us RSP-1098 owners had with the Sub level in the Test Tone menu being 10 dB too low
    13 March 2004, 02:18 Saturday
  • nash
    Subwoofer Test Tone on 1066
    by nash
    I've never really used the LFE output on my 1066 since I use Def Tech towers with built-in subs. With just the towers hooked up to L/R, the sound in movies is great and there's plenty of low frequency response. However, I thought I'd experiment and see how it performed differently if I used the optional...
    26 November 2004, 00:10 Friday
  • J2G360
    rsx 1057 no test tone from left and right speakers
    by J2G360
    I just recently set my rotel rsx 1057 with 5.1 surround. When I go
    into the OSD menu and into the test tone setting I get all tones but
    front left and right. I think it might have something to do with the
    redirect setting in the defat setup menu which says...
    29 August 2012, 23:46 Wednesday
  • zeppelin
    RSP1066 Test Tone
    by zeppelin
    I have 1 question about the Test Tone on the centre channel.
    When I use the SPL meter to calibrate my centre speaker using the internal pink noise from the 1066 at 75db, the centre is set at 0db.
    But when I use the Test Tone from my DVD source pink noise like the "Video Essential"...
    01 June 2003, 01:02 Sunday
  • ka724ka
    RSX-1067 No test tone from Center Back
    by ka724ka
    I just owned this receiver to replace with my old cheap one that I brought 5 year ago.
    The setup was pretty smooth. I hooked up all 7 speakers which I used on the old receiver, when I tried to test them with test tone in the setting, I found out there is no test tone output...
    06 September 2009, 00:21 Sunday
