Major Ground Loop after Direct TV upgrade from Dish.
  • mitch57
    • 429
    Thank You Very Much Direct TV!!! I upgraded (or should I say downgraded) from Dish to Direct TV. I bought a new 50" plasma and upgraded to HD. I knew that this was one of the first things I was going to be looking for after the installation.
    Low and behold immediately after he installed the Direct TV system I turned on my A51, Pre/Pro and the Tivo. HUMMMM.....!!!! And I mean a very loud HUM. It was dead silent before.
    The installer was very aware of the dreaded ground loop problem and helped me isolate it based on some of my inputs. He had to connect a new coax for the dual tuner Tivo so he took it from my cable modem connection in the room on the other side of the wall. And of course the piece of S&%#* Tivo absolutely has to have a telephone line connected to it in order to function.
    I have my sneaking suspicions that the culprit is the introdcution of the telephone line in the mix. The rest of my entire system is connected to two dedicated 20 amp breakers and the ground loop wasn't there before the change over to Direct TV. The reason I suspect the telephone is because there is no change when I disconect the coax cables from the Tivo. I'm thinking it might be a combination of both the introduction of another coax from another system and the telephone line.
    I've killed the ground loop hum so it's back to the way it was before the change over but I really haven't solved the problem. What I did to completely silence the problem is connect a ground wire to one of the screws on the back of the Tivo and connect the other end to one of the metal screws in between the heat sink fins on the side of my Parasound Halo A51.
    Everything is dead silent now but it really pisses me off that I had to resort to the ground wire to solve the problem. I would like to eliminate it the right way!
    Damn those ground loop Gremlins!!! :M
    Mitch
    :stupidpc:
  • Blazin
    Ground Loop.. I hate you.
    by Blazin
    Alright, so as some of you know I've been dealing with a ground loop for some time now..
    I stepped back from the problem as I had plenty of time to deal with it.. I finally did the following:
    - I've moved my Receiver and Computer to a different location that would...
    19 January 2008, 09:05 Saturday
  • Claude D D
    Ground loop hum on RSP1066
    by Claude D D
    I had a nasty ground loop hum when I connected my Infocus X1 projector via the S-Video connection to the monitor out on my RSP-1066.I had the X1 plugged into a Panamax Max 1000+ at the side of my room.When I ran an extension cord from the Max 1000+ to my Monster HTS-5100 and plugged it into the HDTV...
    01 August 2003, 14:23 Friday
  • chanlon
    Ground Loop Hum
    by chanlon
    Any of you folks find the Rotel 1570 prone to experiencing Ground Loop Hums?
    Seems that the Oppo BDP-95 connected via multi-channel analog creates the ground loop with the Rotel processor. If I disconnect the RCA cables, the ground loop disappears. If I use a cheater plug on the Oppo,...
    28 January 2012, 08:14 Saturday
  • Daymond
    Ground Loop Hum and the RSP-1066
    by Daymond
    Just got a 1066 and I am having a problem with what I think is Ground Loop Hum. I have the unit hooked up to a Monster PowerCenter HTS-3500MkII which is plugged in to a grounded outlet with all of my other components. I then disconnected the other components leaving only this processor plugged in along...
    31 May 2006, 21:05 Wednesday
  • Olaf
    RB-1080 humming / ground loop
    by Olaf
    Dear All,
    Like many of you I had a ground loop problem caused by my cable TV connection. Via my dealer in India I was able to obtain a ground breaker (which he had imported from China). This ground isolator was based on breaking the ground connection using I believe windings much like...
    31 March 2004, 03:18 Wednesday
