Need System Configuration Advice
  • bullitt731
    • Aug 2005
    • 92
    After reading posts and reviews here for the last month or so I have been able to put together the following system with some new and some used equipment in mint condition. Having little experience in AV equipment at this level I felt it would be wise to start out in this manner to gain some actual listening experience before I lay out big bucks in the future. I would appreciate any advice on the system as a whole or any weak links you see. I will use it for 50% music and 50% movies.
    Speakers
    USED-Signature 805s
    DEMO-HTM2
    USED-DS7s
    Electronics
    USED-RSX 1056 as processor and amp for center and surrounds.
    USED-RB 1080 for front Sig 805s.
    NEW-Denon 2900.(bought a Rotel RCD-1072 for CDs) Will by new DVD Player.
    Sub
    USED-Velodyne F1000 10"sub from my old system.
    Cables
    NEW-Cattails speaker and sub cables.
    USED-Audioquest interconnects from my old system.
    Thanks for your feedback, Ed
  • Azeke
    • Mar 2003
    • 2123
    Ed,
    It looks like a nice system.
    Are those Roland DS7s apeakers? I am not familar with their acoustical charateristics.
    That being said, I believe in maintaining balance and would therefore try to remain with B&W all around, for symmetry. However, you must listen for yourself, that is the only way to truly judge your system. Just ensure you have tweaked you system properly before acoutical assessment, i.e. set delays properly, speaker calibration via SPL, speaker placement, etc. Your acoustical mileage may actually vary.
    Hope this helps,
    Azeke
    • bullitt731
      • Aug 2005
      • 92
      Thanks Azeke, yes the DS7s are a B & W dipole/monopole surround speaker. As you mentioned I am working on the room acoustics which has been quite an ordeal. I have had two companies look at the room and both have slightly different approaches to the echo problem it exhibits. Its depressing to have to spend 2k on just getting a room to a point where you can enjoy the equipment.
      Ed
      • Shane Martin
        • 2852
        Sub is the weakest link. A friend of mine replaced his Velodyne HGS15 with an SVS pair(2 cs+'s) and the difference was astronomical. He didn't lose the musicality of his Velo either.
        I don't see a display listed either so that could also be a weakness depending.
        • bullitt731
          • Aug 2005
          • 92
          Decided to forget about the Denon 2900 with so many new video enhancements on the horizon. I picked up a mint RCD-1072 instead, at least this way the music portion of the system is pretty complete. I will just have to use my old Denon DVD player until I see what happens. I would like to spend some time acquiring an ear for music again anyway and the 1072 will help in that regard.
          Ed
          • Agostino
            New Member - Advice on 2 channel system
            by Agostino
            Hi all,
            I'm a keen Rotel fan and am now looking for a new 2 channel system and would appreciate advice. The new system will need to drive the below 6 year old German Quadral Phonologue Largo speakers. Unfortunately the below specs not in English specs.
            These speakers are...
            12 February 2006, 17:30 Sunday
          • ladebauchee
            Help choosing new Rotel system.
            by ladebauchee
            i'm Really excited to get a new rotel home theater system. i have a 50 inch fujitsu plasma and currently a sony es system with in-wall jamo speakers. i would love to get the 1098 processor and 1077 amp but i'm concerned about my room acoustics, frankly they are terrible. stone floors, windows, dry wall......
            13 October 2005, 21:23 Thursday
          • Gulicio
            acoustical treatments and finish stage
            by Gulicio
            Oh, where to begin. I am building a dedicated home theater room. I have insulated the walls with R-19 and sheet rocked the walls and ceiling with Quiet rock. The room size is 17' x 22. The floor is concrete with a secondary wood box for the back row of seating. The entire floor will be carpeted. I have...
            03 August 2008, 06:23 Sunday
            Breaking with modern conventions - a highly musical 2-way system using an 8" woofer
            by theSven
            By Jon Hancock
            Reference Speaker system in Development
            Press Release:
            Arvo Parrot Speaker System,
            from Lipira Suction Labs
            It is with great pleasure that we are able to announce the development of the first speaker system by Lipira Suction Labs, the “Arvo Parrot”. Founded as a new development division...
            01 April 2002, 11:37 Monday
