Speakers cutting out, Help Please..
  • D L
    • Aug 2005
    • 5
    Hey,
    I don't know if this is the right place to post this?
    I have a 25 x 32, Detached 2 car heated/cooled garage I just had built. I prewired it for 4 speakers using 16 gauge copper stranded wire. The wires are in 4 places about 7 feet up on a 9 foot high walls.
    I have a Carver HR-752 Receiver rated at 100 watts at 8 ohms that I am using to power the speakers.
    I just bought 4 JBL E50 speakers, Power handling 90W/360 W peak.
    I hooked 2 speakers up to the receiver and when I turn the voulme up past about 70% , the speakers cut off "No Sound".
    Is the speakers the problem or the receiver??
    The Carver receiver has a A an B channel where you can wire up 4 speakers to the back of the reciever. Is this correct? There are 2 buttons on the front of the receiver for either A or B channel use or you can push in both buttons for A and B channel use. I only wired up 2 speakers to A channel to check the new speakers out.
  • Stoney
    • 232
    It sounds like the protection circuit of the amp is activating. I would start by taking an Ohm Meter and checking the load seen by the amp. Disconnect the speaker wires from the back of the amp and check the resistance. You should read about 8 Ohms. If it is lower, you may have a short in the wiring somewhere. Check to make sure you have no stray strands sticking out and shorting at the connectors at both ends. Make sure whatever you used to fasten the wires to the walls hasn't pinched the insulation and created a short. You could try connecting the other set of speakers with a short external wire close to the amp and see if you have the same results.
    Emotiva UPA-700 Amp
    Emotiva UMC 200 pre/pro
    B&W DM605 S2 Mains
    DM602 S2 Surrounds
    DM601 S2 Rear Surrounds
    CC6 S2 Center.
    ASW 1000 Sub
    • D L
      • Aug 2005
      • 5
      I think the Carver receiver just can't keep up, I'll get by for now with it. All the receiver will be used for is to get sound from my local FM radio stations and that's all.
      The speakers are 8 ohms. I mounted the speakers tonight in the garage. Hooked 2 speakers to A channel and 2 speakers to B channel. All 4 speakers are working and I can turn it up pretty loud then it cuts out at about 60% -70 %.
      I will hook the 4 speakers up to my Yamaha RX-V2095 receiver soon and check to see if the speakers will cut off with it. The Yamaha should be able to handle the needed power for the speakers, I would guess.
      I first tested the Carver with about 4 feet of cable on 2 speakers before I mounted the 4 speakers on the wall, They cut out with the 4 foot of wire.
        It may be that the amp is having trouble with the 16-guage wire, which is understandable. That's right at the limit of "useable" guage IMO. Substitute a length of 12-guage similar to that of the 16-guage and see if you have any more cut-out issues. You can find good bulk 12-guage at Home Depot or Lowes for 50 or 60 cents a foot.
        • gcrown22
          Help with 805 Naut. Set up/Receiver Choice
          by gcrown22
          HI- Thanks in advance for your time. I have spent some time reading and there is some great info here and its appreciated. I an an new owner of 805 Naut speakers and htm2 center channel and just some lower end B&W rears for surround. I have several things I would like to figure out for my set up....
          30 April 2008, 14:16 Wednesday
        • toledoguy
          Cables, Interconnects, and Speaker Wire
          by toledoguy
          I'm sure if I dig deep enough into past entries I can find some discussion on this issue. But I'd like to hear some fresh responses. Here's the deal, after years of ok audio equipment, (Sony Reciver, Sony DVD player, Sony CD player, Sony Tape Deck, Sony TV, Sony Front Channel and Subwoofer (anyone...
          05 November 2008, 16:27 Wednesday
        • scruffy57
          Help placing speakers
          by scruffy57
          Hi everyone. I was hoping to get some help placing speakers in my awkward shaped living room. I just purchased a tx-sr607 receiver. I have pinnacle gold aero gels front speakers, pinnacle gold center channel, and pinnacle gold reference for surround. I cannot fit the reference in the living room. I...
          07 December 2009, 00:48 Monday
        • Wick
          How do you match speakers? and Receiver advice
          by Wick
          I just got alot of Best Buy reward points (about $300 worth) and was looking to pick up a receiver. Right now I think these look nice:
          Pioneer 840W 7.1-Ch. THX-Certified A/V Home Theater Receiver VSX-1015TX ($515)
          Yamaha 980W 7.1-Ch. THX Select Digital Home Theater Receiver HTR-5890BL...
          11 January 2006, 22:39 Wednesday
          250 watts Bi-amp VS 400 watts Bi-wire?
          by Race Car Driver
          A question thats been lingering....
          Now, say you had a pair of speakers, with bi wire posts.
          Now heres two scenarios.
          1)Take those speakers and hook them up to...
          *Each speaker gets a mono block, bi-wired, rated at 400watts RMS 8 ohms
          (400...
          16 December 2005, 20:46 Friday
