I am looking into getting a new reciever and a DVD player and a few questions have arisen that no one I know seems to be able to answer.
If the reciever has DVD Audio and SACD capability will any dvd player work to support the formats or does one need to get a DVD player that supports DVD Audio and SACD also?
Also if you had a choice would you chose a Yamaha HTR-5890, a HTR-5860, or a Pioneer VSX-1015TX, or basically anything else that BestBuy sells for recievers. I ask that recommendations are limited to BestBuy's selection because I work there and I can get anything from there for a little over cost. I guess thats one of the perks of the job. I realize that unless anyone has one of the recievers listed that I won't get specific feedback, I am just looking for brand compairison really. I will eventually go to a pre and power setup but this will have to do until I get out of college
I will be using DIY speakers that have a more difficult load ~4ohms, and that has really left me up in the air on this one.
Just tell me what you think..........
.I will be using DIY speakers that have a more difficult load ~4ohms, and that has really left me up in the air on this one.
). I really enjoy the multi channel format that it plays. I will be buying most of my cd's in sacd format from now on.
