I just got a new Denon DVD-3910. There's parts of it that I really like, but I'm having some problems. I know that several people here on the Guide own the 3910, so I thought you could help out. Several things--
1. Can't quite figure out bass management with SACD/DVD-A over the 5.1 analog outputs. Digital audio connections to my Parasound C1 pre/pro work great and sound good. With the 5.1 analog, I was getting NO subwoofer output, even after going into the Denon audio setup, selecting subwoofer-yes, all speakers-small, etc. Finally, I tried selecting Source Direct - YES, which is not well described in the manual and is confusing. I got a subwoofer output, but it was very soft. So I bumped up the subwoofer output in the Denon menu to +10, and now it sounds okay, although I haven't calibrated. Basically, with the analog outputs and DVD-A/SACD, are the only bass management controls that matter the ones in the Denon, and what should be selected?
2. Pluge. Using Avia/DVE, I'm not seeing any pluge signal passed, also known as blacker-than-black. This apparently has been acknowledged by Denon as a problem in units manufactured after August 2004. My build date is October 2004. I called Denon tech support, and as soon as I said "Denon 3910", they said "problems with blacker-than-black, or red?" So this is a known problem. Denon tech said that a fix is coming for this in the next month, but that the chip will have to be re-flashed, requiring the unit to be taken or shipped to a Denon service center.
3. Firmware. When I checked the firmware my unit shipped with, it was -5. I went to Denon's support website, put in my serial number, and it provided me a software update for -9 firmware. I did the update, with no change in pluge. But now my component outputs put out a 4:3 signal, regardless of progressive or interlaced selected. I've even tried re-initializing the unit per Denon instructions and resetting all settings, including a 16:9 display, squeeze mode off, etc. Still 4:3, so if I watch an anamorphic movie on my widescreen projector and screen, it's double letterboxed with black bars on all four sides.
The Denon tech suggested I try doing a unit reset (not a re-initialization) by turning the unit off with the on/off button, then turning it on while holding the "STOP" button. I did this, and all it did was a normal power-on sequence.
Does anybody know how to RESET Denon 3910 players? Apparently powering it off and pulling the power cord doesn't do it either.
