Hope someone can help.My bro is about to buy a hdtv and has come down to the following models.Samsung hlp50663w,Mitsubishi wd52525 and toshiba 51h84.We realize that the sammy and mitsu are dlp.All these sets looked great at the store but obviously a fair comparison cant be done there.Please he is about to plot down for the purchase and would like to find out which is the better in everyones opinion that is valued here.
HDTV selection help asap?
In my opinion, the Mits is the best of those three.
I personally don't think the XX63 models from Samsung have very good picture quality. My neighbor recently decided to spend an extra $500 to get the Samsung 4674 over the 4663 because the picture quality was that much better. And the Mits 52525 has an even better picture than the XX74 line in my opinion.
As far as the Toshiba, if I was seriously considering a CRT based tv, I would lean toward Mitsubishi crt's over the Toshiba. Yes, I am a Mits fan, because they make excellent products.
Tell your bro to get the Mits, he will be very happy.- Bottom
by arazi13Im hoping someone can help me with a problem i am having with my Samsung Dlp projection HDTV. Hopefully i uploaded the jpg properly and the issue is clearly visible.
On the left hand side of the screen from the top to the bottom you should be able to see a 1-2" thick shadow where...-
Hi!
I just purchased the Toshiba 57HX93 last weekend and have it installed into our family room. High Defination broadcasts are aquired courtesy of the Bell ExpressVu 6000 HD Satelite Receiver.
We had made some changes in the house in which the downstairs Theater room was converted... -
by VikingPHi,
I am starting to think about changing my little 20" TV, and would like to know if anyone has any recommendations on a good set. Every time I go for an upgrade, I always end up changing something in the sound domain, and completely leave out the video (in my defense, I listen... -
by palmettoi am planning a HT system with the Samsung 61" DLP, which has a DVI input. my sources will be DirecTv for HDTV and OTA broadcasts and an occasional DVD. i want to get the best, latest HDTV satellite receiver as cost for this line item is not much, comparatively, and i am willing to go with the... -
by LexHere's my "new" DVD player, the Samsung DVD-HD1000.
This DVD player was really a surprise. I'd not heard of it, until accidentally finding one used on the net. Not knowing what it was, I went to the Samsung site to research it. What I saw was a beautiful player, that exuded...-
- Loading...
- No more items.
