LCD monitor for VHS movies
  • choppi
    Hello - This is my first post on this forum.
    I have a large (1,500) collection of VHS movies and, through my system, they sound very good. Therefore, I have no desire to switch to DVD (although, in time, I will get a DVD player for the same reason I finally got a CD player; the analogue formats are insufficiently supported by new output). I have been using a Sony Trinitron 20" monitor which I found in a dumpster about ten years ago. It looks good but has the word VIDEO on the screen (at top right) at all times. The tuner is broken (and I have not watched TV for 10 years and do not miss it) and I use an RCA cable to send the picure from my VCR player to the monitor.
    My question is: I now wish to buy a LCD monitor of about 32" size (in movie format, not tv format) to watch from 9 or 10 feet distance.
    How will my VHS movies look on an LCD monitor of this size at this distance ? Is there a particular "resolution refinement circuit" that I should look for in the monitor I select ? I would especially like to hear from someone who has actual experience with the VHS format on the new high-rez monitors.
    Any help greatly appreciated. I would hate to spend $2,000 or more and get it wrong !
    Thanks - choppi@mac.com
    Earl, welcome to The Guide. :welcome:
    A hi-res monitor will definitely make plainly visible the lower resolution inherent in a VHS tape, but with a 10' viewing distance for a 32" monitor you'd be past the optimal distance for DVD viewing, which (I'm thinking) will be just about right for a VHS tape. The vertical resolution of VHS is about half that of DVD so at 10' you should be at enough of a distance that the image will look fairly seamless. Any closer though and the low resolution will be VERY obvious.
    Good luck and keep us posted. 1500 tapes, eh? 8O
    • Uncle Clive
      Former Moderator
      • Jan 2002
      • 919
      A Warm Welcome :wink:
      Using very good cable/s would also help in this reguard.
      CLIVE
      • woodman
        A primer on "resolution"
        by woodman
        There's been so much confusion and misunderstanding about this aspect of HomeTheater, that I decided to post a primer on the subject to try and help those that are unsure about it, or even worse - are totally confused.
        To start with, those who've grown up with computers need to learn...
        28 September 2002, 17:01 Saturday
        Computer Monitor Screen Resolution Survey
        by Lex
        PLEASE answer survey above AND list specifics as follows, it's important! (Even though this is computer related, I put the survey here for maximum exposure. I may move it after everyone has a chance here to what seems the more logical location of the computer area.)
        (Note, the reason...
        Use std 600 X 800 @ work, but higher rez @ home. List specific rez, & enter poll
        4.44%
        2
        Use higher than 600 X 800 rez @ work, but use std 600 X 800 graphics @ home. List specific rez.
        2.22%
        1
        I run std 600 X 800 graphics both @ home & work. Answer Poll, will this chnge in future?
        0.00%
        0
        I run higher than 600 X 800 rez graphics @ home & work. Answer poll, list specific rez for both.
        91.11%
        41
        I don't know or don't care what I run as long as I see an image.
        2.22%
        1
        12 June 2006, 11:05 Monday
      • Michele Spinolo
        1098 and TFT monitor native resolution
        by Michele Spinolo
        Does anyone know which is the native resolution of the 1098's tft monitor?
        Bye
        Michele
        26 December 2003, 13:07 Friday
      • misterdoggy
        External MONITOR menu instead of LCD on C1
        by misterdoggy
        I was wondering if anyone uses an external monitor instead of relying on the LCD on the C1. Even though I'm no spring chicken, I can read pretty good at distance. The distance between the couch and the LCD is about 5 meters (16 feet) and I just can't read a thing and its bothersome. I have confidence...
        11 June 2005, 02:15 Saturday
      • julienb
        SanyoPLVZ2 => cannot reach maxi resolution (dvi+geforce4)
        by julienb
        Hello !!
        - I use a Shuttle sn41g2 v2 (it contains a NVIDIA GeForce4 chipset) with a cv22 DVI AGP Card.
        - My OS is XP Pro sp2
        - I have a Sanyo PLV Z2
        I have some problems :?
        I use a Nvidia Driver (66.93, the latest)
        I put "Auto...
        04 December 2004, 10:04 Saturday
