Mixing balanced and unbalanced
  • sbank
    • 20
    Hi All,
    I have a question pertaining to mixing balanced and unbalanced interconnects. My dealer recommends in keeping everything one or the other. (eg all balanced or all unbalanced)
    I currently have a Rotel RB-1080 2-channel Amp for my fronts. I've been using for quite a while, balanced XLR cables to feed this from my pre/pro. I just recently picked up a Rotel RMB-1075 5-channel amp. But this amp does not have balanced connections (and I have no desire to upgrade this new amp. (At least not yet ).
    So my question is this, should I replace my XLR cables with some good RCA cables for my fronts? Or should I just go in my pre/pro settings and adjust the levels so that I get equal sound pressure and keep the two fronts as balanced and everything else as unbalanced?
    thanks as always.
    Steve
    • 16081
    Short answer? Whatever makes you happy- really!
    Longer answer is that MOST consumer electronics at this level are implementing balanced connections by using an additional converter/driver stage and reciever stage, so running unbalanced will be slightly less electronics in the signal path. This type of active balanced circuit also doesn't have the kind of stellar CMRR (common mode rejection ratio) that you get with good transformers. So, if you're gear is on the same outlet feed, and your interconnects are less than 20 ft or so, there's probably no advantage at all to going balanced.
    Note that some gear, like Ayre, BAT, Theta digital, actually uses circuits that are balanced differential all the way through; for these, using full balanced connections is the best way to go.
    Now, if you're keeping your original Rotel for the fronts, and it's working fine connected as is, I can't really see bothering to get a new set of interconnects to switch to unbalanced, unless you were making a clear upgrade on the interconnect quality.
    ~Jon
    • sbank
      • 20
      Thanks jonMarsh for the reply.
      I read through (before I wrote this post) a previous thread on balanced interconnects. And I learned that the Rotel's balanced connections aren't truly balanced. (I'm guessing my Bryston pre/pro is tho). And I also read your comments in that thread.
      My main concern is with the output levels of mixing the interconnects. My dealer said that I would lose (I think he said) 3 dB of signal. And he drew a nice little sin wave that I remembered from back in HS. But I'm not sure what it all meant. (Something along the lines of the amplitude of the balanced signal is double that of the unbalanced signal).
      The way he was talking, seems to imply that by mixing balanced and unbalanced, I would somehow lose some of the signal. (Not sure if I am making myself clear, since I am not really sure I understood what he meant.)
      Now if this is something that I can just compensate with my pre/pro settings, then I think I will do just that. (Instead of buying an additional pair of interconnects.)
      But If I somehow lose `something' (not sure what something is), then I'll just go with unbalanced all around.
      Steve
        • 16081
        Your amplifier sensitivity may differ on balanced and unbalanced. You won't lose any signal level; you just may need a higher level for either the amp with the balanced input, or the other- it depends on what their rated sensitivity is. Your preamp can put out more than either needs, and the level matching is setup when you match the speakers for playback, anyway.
        A Non-issue, in my opinion. Someone at your dealer is trying to be helpful, but probably doesn't really understand.
          Twin Moderator Emeritus
          • 16706
          I totally agree with everything Jon said :T You may be able to sell your used XLR cables and upgrade to som high quality RCA's to get everything running unbalanced but I don't think you have much to worry about either way.
          • goskers
            • 106
            Can someone give me an idea of how the balanced outs of the benchmark dac1 and aragon 8008bb are? I would be interested in using them but of course not if they were not designed well.
              • 16081
              The Benchmark DAC1 uses differential DAC chips (balanced) and continues the signal path to the output this way- so I would call it a "true" balanced output, though not quite in the same way as an Ayre CX-7, in which the audio circuitry is an actual balanced differential amplifier.
              Now, the Aragon BB is a single ended amp, and the balanced input is an "add-on" circuit. So, conventional wisdom would be to skip it...
              So, how come my Aragon 8008 X3 sounds better running on the balanced inputs through my NFB preamp than unbalanced, or even unbalanced through a pure passive preamp? Is it the Ayre Signature balanced interconnects, versus some older Cardas unbalanced cables? I don't know... it just sounds cleaner and actually a bit less tizzy in the highs.
              So, if you have an Aragon BB, I'd suggest trying it both ways if you have an opportunity to do so by borrowing similar interconnects or some other way that avoids breaking the bank. My balanced interconnects to the amp are 3 meters long. You don't want to know what MSRP is for those puppies. Even the "very friendly" price was close to the cost of my DAC1. But they're stellar- they should be, development took over three years of work between Cardas and Ayre.
              Best regards,
              • goskers
                • 106
                Thanks Jon,
                I was trying to figure out if it would be advantageous to source a BB instead of ST. I have some pretty darned good 'regular' interconnects so I was just wondering if running balanced all the way through would be beneficial. I guess the best thing about the BB would be the PS and driver increase.
                  • 16081
                  If you have a true balanced preamp, then running balanced all the way through would make some logical sense.
                  I recommend the BB's for the PS and output transistor SOA improvement. BTW, the extra output transistors lower the open loop distortion, so even apart from power handling, it's a worthwhile change for the BB. I'm considering a further mod to the Xmod which would increase the max number of outputs for the very same reason... the trouble is, this whole exercise is getting to look a lot like Kramming a Krell into an Aragon chasis.
                  OTOH, a double decker PCB layout may actually reduce costs, as then I may be able to get by with just double sided PCBs instead of the four layer boards I'd been pondering. So many ideas, so little time...
                  ~Jon
                  • MIB
                    Subwoofer connection. Balanced/unbalanced.
                    by MIB
                    Hello.
                    I am just about to take delivery of an SVS P2B+ subwoofer.
                    Currently I have a Parasound C2 pre-amp processor.
                    Connected to it are 7 mackie 624 active speakers.
                    These are connected to Balanced outputs XLR to XLR connectors.
                    04 May 2004, 09:44 Tuesday
                  • Fre.Mo
                    balanced input for RC1090
                    by Fre.Mo
                    I am in FRANCE. I bought a RC1090 pre amp and I would used balanced input on XLR connections.
                    Please can you tell me if this amp uses :
                    - the USA xlr system (1: GND, 2: COLD, 3: HOT)
                    - or the European system (1: GND, 2: HOT, 3: COLD).
                    My Cd...
                    13 July 2005, 08:38 Wednesday
                  • cfrahme52
                    Balanced vs unbalanced interconnects
                    by cfrahme52
                    Although the Rotel RC1090 and RB1080 allow for either balanced or unbalanced connections, I believe I read somewhere on this forum that with Rotel gear there is nothing to be gained going the XLR route.
                    Is this so? Why?
                    I've been toying with the idea of purchasing a balanced pair of Nordost...
                    26 February 2006, 14:30 Sunday
                  • sonicbaer
                    RB 1090/RC 1090 balanced and unbalanced ?
                    by sonicbaer
                    Hello
                    I hope someone can answer a couple of questions regarding the RC 1090 and the RB 1090 balanced connection switch...
                    What does the switch do ? why does the manual say that both balanced and unbalance connections should not be used at the same time ?
                    24 August 2007, 17:33 Friday
                  • shuang1234
                    The truth about balanced inputs and outputs
                    by shuang1234
                    I have noticed a number of posts disqualifying the Rotel 1098 from consideration due to lack of balanced connections. I stumbled upon a few interesting articles that explain pros and cons about balanced connections.
                    In a nutshell, unless you have serious noise problems or a high-end system...
                    27 July 2003, 21:57 Sunday
