Open to suggestions for multi channel amps!
  • PMazz
    • May 2001
    • 861
    Since i've always owned receivers, I have no intimate knowledge of amps. I'm looking to actively biamp some new mains, (nudge nudge, wink, wink Tom and Jon) and will need 4 channels for this. Of course the Ref50 is about to be launched and going to seperates would also require 5 more channels. My initial thought is to get 2 5 channel amps. Sherbourne and Outlaw pop to mind, right off the get go, but need any and all advice/ideas/alternatives without breaking the bank, of course. $1200 or so each for these is probably near the limit for me. I'm guessing 100 watts/channel is minimum?
    Pete
    Birth of a Media Center
    • 27460
    Two points here. Buy used and get as much power as you can afford. That's the best way to maximize your amp dollar. What if you could find 2 Aragons and a big Parasound 5 channel maybe?
    Well, it's a thought.
    Lex
    • Pat
      • 1643
      Pete, you could always take a listen to Anthem.
      I have one of their 3 channel amps (MCA-3) and it is great.
      Pat's Page
      Pat's Page
        • 16178
        In the price range you're considering, I'd second the vote for an Athem. You won't find a multi channel Aragon in that price range, not even an X3. The Aragon would have more power, and be able to drive pretty much anything. The Anthem may be a bit more refined.
        For the off shore manufactured Amps, I'd suggest Rotel for the top end, and Parasound for the bottom end if you biamp. That's where their strengths lie. Using an Anthem for the top end would be fine, also.
        Of course, if it were my system, and money wasn't a serious issue (dream on, Jon!), I'd go with Ayre V-6's. At least on the top end. That would be pretty killer, Ayre mid and high's, with an Aragon bottom end. I know from experience; that's how I had my X1's biamped when they were last setup. Now I'm working on Aragon mods with no loop feedback, and an upgrade for the X1's to Seas Excel woofers. But the X1 upgrades won't happen until after the Arvo Part is done and the "Mano e Mano Array" has been built. At the rate things are going at work (work and renumeration wise), that could be a while! :LOL:
        -Jon
        • PMazz
          • May 2001
          • 861
          Found a few Adcoms but no Anthems so far. Do they have distribution over the net or is it a local HiFi thing?
          Some decent pricing on B&K 7250s also. I guess the new rollouts will have folks upgrading. Worth the bucks?
          Pete
            • 27460
            Well, one never knows what he will find. Check the expiring today auctions at ebay, audiogon, etc.. every day.
            BK maybe not to bad, but personally, not much experience there.
            Lex
            • PMazz
              • May 2001
              • 861
              Well, I found a good deal on a B&K 7250, 200 W x 5 amp. Check's in the mail.
              Thanks for the advice.
              Pete
              • sunggipark
                Is Rotel introducing 7 channel amps?
                by sunggipark
                I've read on another forum post that Rotel is going to introduce a couple of 7 channel amps to replace the current 5 channel amps.
                Anyone have any info/details and the expected date of introduction?
                16 October 2004, 23:03 Saturday
              • jjahshik32
                how ares Sub woofers connected to 2 channel amps?
                by jjahshik32
                are 2 channel amps capable of sub woofers and if so how would u connect them, just curios on how its done on 2 channel..
                20 September 2007, 22:10 Thursday
              • Kevin P
                6 or 7 channel Amp recommendations?
                by Kevin P
                As I've been reading people's posts on their new pre-pros, I've been researching my eventual move to separates myself. Although I can't afford to upgrade yet, I'd like to be prepared for when I can. Although I've been reading posts on pre-pros, I've come to realize I really should be researching amps...
                11 June 2002, 14:44 Tuesday
                Using 2 Krell multi-channel amps as monoblocks?
                by ShadowZA
                I just thought of something regarding 2 channel critical music-listening only. Don't know why I didn't think of it before.
                I have 2 Krell KAV amps. One 3 channel & one 2 channel. Each amp has a 2000VA power supply. At the mo' I have LF, centre & RF on one amp & SL & SR...
                01 June 2008, 13:18 Sunday
              • rich0372
                2 channel vs 5 channel amp
                by rich0372
                Hey all I allready have a rmb 1080 for fronts and now can possibly get a good deal on a rmb 1075 now I was considering two 2 channel amps before this good deal came about { I was told 2 channel amps sounded better} How much better? I know damping is much higher on 2 channel and how much better for center...
                22 July 2004, 13:13 Thursday
