ı am very new here and ı wonder if possible to go deep tight and loud basses under 70 herts in less than 1 liter enclosures ,sound should be clean ,clear and natural very less comprimise desired.it might not be high - end but better than many hi - fi,ı know its not possible to do all in one but what can be the closest point you can get .ı am thinking to use peerless tympany ne 65 full range driver in 11 cm diameter hdpe with 1 cm thick wall enclosure .has anyone used this driver and any comments wellcome.
how deep and loud you can with smal full range drivers less than 1 liter enclosure
by fshaganI'm going to build the TriTrix MTM speakers, and have a question about the enclosure choices (the article at Curt's Site details three choices, sealed, vented and transmission line).
The speakers will be incorporated into my eventual 5.1 set up that is now a 3.1 system with a Velodyne...-
Channel: Mission Possible DIY
by anglerz007I have decided to build a subwoofer based off reccomendations from SteveCallas and others on AVSforum. Here are the specs:
--Sound Splinter RL-P15 D2 (dual 2 ohm voice coil [wired in series for 4ohm load])
--Crest CPX900 (bridged 4ohm for 900 watts)
--260 effective liter...-
by kjgarrisonHello everybody. Love this site, btw. I just spent an hour looking for something similar enough to my situation. No luck, so here goes.
gawd... I just looked at this and it is waaaay too long ...
I have an "entertainment center" that I hope to install in-wall...-
by AntonHi Guys,
I’m really interested in cloning the Sunfire XT CRM-2 for my stereo listening. They have an interesting look and possibly an enjoyable sound, If I make them right.
From the image it appears that the planar tweeter is a Silver Flute YAG-20 (Dayton PT2B-8 ), with two high...-
by ErrolPJust received my 305 and now in the process of tweaking my setup. I was hoping for some help, advice or general commentary on a few things I currently am trying to setup. For a better idea of my environment, I have B&W 804's with a B&W HTM2 for my mains and center. I also have a FS12 Velodyne...-
Channel: Club Rotel
15 February 2002, 16:51 Friday -
- Loading...
- No more items.
