I'm going to build the TriTrix MTM speakers, and have a question about the enclosure choices (the article at Curt's Site details three choices, sealed, vented and transmission line).
The speakers will be incorporated into my eventual 5.1 set up that is now a 3.1 system with a Velodyne VX-10 subwoofer. I like the idea of getting lower sound out of the TriTrex, and favor the vented or transmission line enclosure. But there may be a potential problem.
Because of a small room and the ever-present WAF, I will have the speakers in the "entertainment center niche", a 30" deep recess in the wall that measures 81" wide X 63" tall starting at 32" from the floor. The planned TV is 50" wide, so there is room for speakers on either side of the TV. AV equipment will be set in a horizontal 'cabinet' under the TV that will be about 20" tall and can either go full width or something less to accommodate the speakers. I have two concerns about the TriTrix enclosure.
1) Bass response ... is it likely that with the vented or TL enclosure, with openings in the rear of the speakers, gets "boomy" or muddy because they are tucked into the niche in the wall? Would using the sealed enclosure be better (or perhaps another design entirely)? Or could I use the Triune vented enclosure design that has the vent on the front of the speaker to avoid this?
2) Height of the speakers ... the "floor" of the niche that the speakers will be on will be either 32" from the floor, or 52" if I build the horizontal cabinet full width. Is there a concern with the TL version of the enclosure, with the tweeter at either 58" or 78" from the floor? (I'm assuming the woofers are less important in this regard).
