Infinity power issue !
  • madmac
    • Aug 2010
    • 3122
    Hey all,
    My older Infinity sub (circa 2003) usually turns itself to an off/standby position when it has not received a signal for a period of time. Last night I noticed that it was basically not doing that and is stuck into a permanent 'ON' position. I tried turning it off for the night but when I turn it back on, it basically stays on. It still works fine however.
    Could be worse right? It could be stuck into the Off/ standby position and not work at all!! So other than the power consumption issue, I am going to leave well enough alone unless someone here has an idea for an easy fix??!!
    Dan Madden :T
    i am guessing.....maybe the relay or a component in the voltage sensing circuit?
    did you try cycling the power by plugging & unplugging from wall outlet?
    • madmac
      • Aug 2010
      • 3122
      Thanks Bill.......I'll try that and get back to you.
      Dan Madden :T
      • madmac
        • Aug 2010
        • 3122
        I got home from work yesterday and the sub was making some continuous low level pink noise sound. I turned it off and unplugged it. This morning, I plugged it in again and it's making some humming noise but it still works. When I switch it from line in to speaker driven it kinda' makes some popping noises as well as when I switch other controls on the back.
        I'm thinking that I will pop off the back control panel and to a clean up inside there. It sounds to me like typical stuff that would happen to older, dirty electronics.
        What do you think ?
        Dan Madden :T
        • madmac
          • Aug 2010
          • 3122
          Update!!!
          Well, I popped of the back panel where all the electronics, crossovers, and sub amp was located and blasted everything with compressed air and then with contact cleaner. I reassembled and left it overnight to dry out.
          Unfortunately, the problem still persists. The sub stays continuously on (Which I think is because the pink noise rumble is making the sub think there is a signal). The unit is also quite hot as well. I tried disconnecting the RCA line in, which makes the rumble quieter but not gone. I also tried switching the sub to run off the speaker wires rather than the line in but the rumble is still there but less so.
          However, at the end of the day, the sub still works and from my listening position, I cannot hear the rumble. So other than any ideas you guys can give me, I think I'm just going to live with it and turn the sub off when I'm not listening to it.
          Any ideas or feedback is welcome !!??
          Dan Madden :T
            • 4158
            Well, since you tried both inputs there is no need for me to suspect your receiver. Did you inspect the capacitors while it was apart? If not, it's worth a shot. You're looking for bulged tops and/or leakage from them. I am not an EE, but I wonder if it is a filtering problem. My gut says check the caps. Then again my gut is enjoying Newcastle Brown Ale at the moment. LOL. I tend to look at caps for three reasons #1) They cause all manner of poor behavior when they go bad. #2) They go bad. #3) They are something I've found easy to replace, allowing me self congratulatory back patting. That last part is optional, but if you fix something you should get that perk.
            • madmac
              • Aug 2010
              • 3122
              Thanks Lee but if a cap has gone bad wouldn't the unit stop working altogether?
              I couldn't believe how complicated the electronics are inside this speaker. I really wouldn't know where to look to be honest. I was rather impressed at how much technology went into this speaker. To be clear, these Infinity's are powered towers. The subs are built into the bottom of the towers. Infinity Interlude towers IL50. So that being the case, when I pop the back panel, I'm looking at the speaker's crossover, the amp for the sub and all the electronics for that amp as well as all the various switches etc. It's super complicated!
              Dan Madden :T
                • 4158
                Ahh. I see! That does sound like a nest of "What the heck is that?" You won't necessarily lose everything from one (or more) capacitors failing, or starting to fail, but I completely understand not wanting to start taking apart something like that. The smart guy is the one who knows when to say 'when'. :T
                • madmac
                  • Aug 2010
                  • 3122
                  And the old saying......"If it ain't broke, don't fix it" saying. The sub works so I'm not going to mess with it!!
                  Dan Madden :T
                  • madmac
                    • Aug 2010
                    • 3122
                    UPDATE!!
                    Ok.......Now the sub has failed completely! No power....no light....no sound (I checked the fuse and it's fine). That being said, I'm perplexed as to whether to have it fixed or to just buy another sub. The amp itself could be toast!! The other sub in my right tower still works fine and as I stated earlier, I'm shocked at how little difference the lack of the left sub makes to the overall LF/LFE sound performance.
                    The tower weighs 80 pounds so I'm reluctant to bring the entire thing in for repair and I am thinking that I could just bring in the back control pannel, which houses the amp, crossover etc for the entire speaker. Could that work? Who could do that is another question??!!
                    OR.......I could just buy another.....better.....bigger sub. I'm figuring it would cost in the $200+ bucks to have it fixed right?
                    What are your thoughts my HTG friends??..........HELP??!!
                    Dan Madden :T
                    • Kevin P
                      • 10812
                      Well, if you're good with electronics you could troubleshoot the thing, replace the failed component(s) and be back up and running with a minimum of expense... but it sounds like maybe you're not like that. If the capacitors are going, they can cause issues and as they get worse, it could stress another component and cause it to fail.
                      Another common issue with modern electronics are the solder joints, with the lead-free solder being used now they're a lot more prone to failing. They can generally be fixed with a soldering iron or a hot air station.
                      But, if you're not someone who can handle fixing it yourself, perhaps a call to Infinity to see if you can either (a) send the module in for repair or (b) purchase a replacement to install into your speaker.
                      • madmac
                        • Aug 2010
                        • 3122
                        Thanks for your input Kevin. I did pop off the back panel and it's quite complicated as it houses the crossover for the speaker, the amp for the sub and various other electrical stuff for the other sub options etc. I am pretty good with a soldering iron but I really wouldn't know where to being to look for the problem.
                        Dan Madden :T
                        • madmac
                          • Aug 2010
                          • 3122
                          Well......I contacted Infinity and they have offered to look at it and possibly fix it. They have also offered the option of bringing in Just the electronics only so I don't have to lug in the whole damn speaker (80lbs!).
                          The most it will cost me is $45 bucks if they can't fix it so I'm going to go for it !
                          Wish me luck!!?
                          Dan Madden :T
                          • captainlack
                            Rx-950AX stuck on standby
                            by captainlack
                            Hey all...
                            I just received an older model Rotel receiver from a friend and hooked up everything hoping to get my brand new (to me) receiver playing and alas...it seems to be stuck on standby. I've noticed that this seems to be an issue with some Rotel receivers in the 1000 series...but...
                            28 February 2008, 00:49 Thursday
                          • Kobus
                            CDP transport issue
                            by Kobus
                            Has the issue regarding reading the first disk been addressed. I see there is no firmware update for this. Also no further discussion by those of you affected. I am surprised as it is a couple of months now.
                            The reason I am asking is that a friend recently got a 102 with the same issue.
                            15 February 2007, 09:00 Thursday
                          • Bluespower
                            1068 Stuck in Standby Mode
                            by Bluespower
                            Got home tonight and found that my 1068 would not power up out of standby mode. I cycled the on/off switch on the back of the unit a few times with no luck. I disconnected the power cord and waited a few minutes and still no luck. Is there something else I can try OR is it ship it to the repair center...
                            17 July 2006, 20:44 Monday
                          • Karma
                            The "Pile" or How to Stack and Not Get Stuck
                            by Karma
                            HI All,
                            Ordinarily I would not recommend stacking equipment. I can't tell you how many times I have lectured my customers against such practices. I have strong opinions against stacking.
                            That said, my 6 month old bedroom HT system has stacked equipment and it works very well. The...
                            27 April 2006, 07:56 Thursday
                          • sargebuckey
                            Introduction and question regarding SSP-300 issue
                            by sargebuckey
                            Hi All,
                            I would like to introduce myself as the new owner of the Classe system. I owned CA-3200 and CA-2100 amps for about a year connected to Denon 5803 as a pre-amp. Recently, I decided to purchase used SSP-300 (due to the budget constraints) on Audiogon.
                            Processor arrived in a great...
                            27 March 2008, 02:59 Thursday
